Replace Blower Motor Resistor (Tool Used) - Ford Powerstroke Diesel Forum
post #1 of 7 Old 04-20-2013, 09:26 AM Thread Starter
In my attempts to replace the Blower Motor Resistor in my 2008 F250 truck, the location of this resistor is in a tight spot behind the glove box.
My question is, if anybody has replaced this resistor before, what did you use to remove the 8mm screws on the housing? I got the left one off,
but the right one is in such a position that it is difficult to get an 8mm socket/ratchet to get it out. Any tips?
alby is offline
post #2 of 7 Old 04-20-2013, 11:44 AM
I used a variety of short and long extensions and two swivels. The biggest difference was having a buddy to turn the wrench while I tried to hold the socket on the screw. I went from the side of the dash squeezing the socket between a bunch of wiring looms ect. Good luck and whatever works.
Have a good one,
Pete
2009 F-350 XLT CC LB 6.4 powerstroke, H&S mini maxx, Flo-pro 5" dp back exhaust, AFE intake...
1977 F-150, built 300 six, M5OD 5 speed
Mercmarquis is offline
post #3 of 7 Old 04-20-2013, 01:55 PM Thread Starter
Thanks. The Ford Engineer who designed it to be in this location should be shot.
Or it is a conspiracy to make one give up and take it to a dealer who charges
$120/hr and uses a special tool that does it in 2 minutes. lol
alby is offline
post #4 of 7 Old 04-20-2013, 10:54 PM
srjd's Avatar
Quoted: 2 Post(s)
I just used a socket with extension. Pain in the rear but took a lot of patience lol
01/07 Job 1 F350 H&S Tuned. ARP Studs, AFE 4'' straight pipe, EGR delete with elbow, AFE stage 2 CAI, 6'' lift on 37s, 20x12 Fuel Nuts two piece, Sinister coolant filter, CCV Mod, Projector headlights HID kit
srjd is offline
post #5 of 7 Old 04-21-2013, 05:16 AM Thread Starter
HHahahaha, I think that appears to be the magic tool, "patience".
Maybe I'll devote next weekend to getting that 2nd screw out. lol
alby is offline
post #6 of 7 Old 04-21-2013, 11:28 AM
srjd's Avatar
Quoted: 2 Post(s)
I had a much harder time getting the one screw back in but a magnet would have fixed that.
srjd is offline
post #7 of 7 Old 04-22-2013, 07:23 AM
chachi65's Avatar
If u have a 1/4" air ratchet that is the best way only takes about five min. That way
chachi65 is offline
