Lookin to buy an 08, help plz! - Ford Powerstroke Diesel Forum
post #1 of 6 Old 04-17-2013, 09:26 AM Thread Starter
MDRhoads360587's Avatar
I'm goin to go look at a few 08s this weekend and was wanting to know what things I should be asking about and what to look for. I bought a 6.0 without askin questions first and didn't want to run into that mess again lol. Any suggestions would be appreciated. Thanks!
2004 F-350 Lariat FX4 CCSB, Lariat, FX4
5% Tint All Around
MBRP 4" Straight Pipe
ARP Head Studs
Ford Gaskets
Sinister EGR Delete
New Oil Cooler
Cat ELC
Sinister Coolant Filter
Blue Spring
SCT Livewire
Shell Rotella T6 Synthetic Oil
Motorcraft Filters
MDRhoads360587 is offline
post #2 of 6 Old 04-18-2013, 02:26 AM
Mikers's Avatar
Check the history and maintenance intervall was correct
2008 F350 DRW Powerstroke
1993 Ford Bronco 5.8
1990 Ford F150 5.0
1955 Ford Customline
1993 Ford Escort RS Cosworth (Racer)
It exist only Ford and then comes the rest
Mikers is offline
post #3 of 6 Old 04-18-2013, 02:34 AM
BIG Laing's Avatar
Job 1, 2, and 3? If you don't know what that means, search and read! As long as all TSB's were preformed, you should be good.
2013 Lariat Eco-Boost F150 Super Crew 4x4 20K Miles. Max-Tow 3.73's, luxury package. Amp Steps, Raceline Raptor Wheels, Bak-Flip, and much more.
BIG Laing is offline
post #4 of 6 Old 04-18-2013, 02:34 AM
BIG Laing's Avatar
TSB's and scheduled maintenance...
post #5 of 6 Old 04-18-2013, 05:15 AM
muntu's Avatar
coolant
an oft overlooked thing is coolant condition even tho oil,fuel,air filters are done on time. if you are shopping at a dealer over the w/e oft as not the service side is closed so you cant get them to stick a test strip into the degas/coolant bottle. coolant service requirements are shown in the service manual but there is no where that tells you to check nitrite levels with the test strip.....I needed a complete flush at 15000 miles...kinda peed me off... figured ford should have taken care of it it can be expensive to make o.k. especially if you are looking at a full flush.
2008 6.4 job3 F250 3:55 gears 10K gvw silver stretchcab 8ft box.timbrens and goosenek hitch.51 gal aux tank.
muntu is offline
post #6 of 6 Old 04-18-2013, 05:42 AM
Real Men of Genius
Super Diesel's Avatar
Quoted: 10 Post(s)
Feedback Score: 9 reviews
The 6.4 basically has the same common failure points as the 6.0 - if you've been thru that already, then you know what to look for. I also concur with looking into if it's a Job 1, 2, or 3. Personally, I wouldn't buy a 6.0 without studs... and I feel the same way about the 6.4, especially since it's very easy to make crazy power with them.
Not sure about the emissions laws in Indiana, but another thing that would be a big plus to me - would be if the truck had the all of the appropriate deletes and an H&S Minn Maxx programmer on it. (The H&S Minn Maxx isn't a necessity, but that would be a huge plus) - However, my goals for getting a 6.4 would be to make power. Not sure what yours would be. Good luck with the hunt!
Chris | 2005 F-250 RCSB | "Ranger - Turbo Diesel V8"
CED Compounds - Conventionals - Supporting Mods
Super Diesel is offline
