Fuel - Ford Powerstroke Diesel Forum
post #1 of 6 Old 04-15-2013, 06:16 AM Thread Starter
Fuel
Ok I know this is probably a stupid question but I'm new to diesels. I got the mini max and if I run the egr delete and dpf delete I can still run the ultra low sulfur fuel right. I just saw something in the instructions about high sulfur fuel. Thanks
ajhester is offline
post #2 of 6 Old 04-15-2013, 06:26 AM
zdawg8394's Avatar
high sulfur is a tune that is offered by H&S that allows off road use, if you have a new mini maxx then the only way for you to get that set of off road tunes would be to send a form to the epa and then they make it so your truck cant be registered for highway use.
but anyways you can still run ultra low sulfer (15ppm) and i dont think you can find high sulfer commonly. i think off road fuel is 300ppm?
zdawg8394 is offline
post #3 of 6 Old 04-15-2013, 07:24 AM Thread Starter
Ok on the mini max I have a hot damn tune I can use. Is that the one I would have to have a form on
ajhester is offline
post #4 of 6 Old 04-15-2013, 07:43 AM
superduty6.4's Avatar
The term high sulfur is also used on the older style of mini's as well as the new on road versions after one of the recent updates. If you haven't submitted any info to h&s but still have access to all the tunes then you must have the race version. Which part # is your mini?
08 F350 JOB 1
H&S MINI MAXX HD300 W/S1M
SINISTER EGR/COOLER DELETE
6000K BEAMERS HID HEAD & FOGLIGHTS
KMC XD WHEELS W/NITTO TRAIL GRAPPLERS
2.5" LEVELING KIT
DIESELSITE COOLANT FILTER
ROTELLA EC-1 RATED COOLANT
5" DP BACK FLO-PRO EXHAUST
FLO-PRO CAC PIPE & INTAKE ELBOW
CCV MOD
AIR LIFT 5000LB AIR BAGS W/ONBOARD COMPRESSOR
AFE CAI
PMF TRACTION BARS
superduty6.4 is offline
post #5 of 6 Old 04-15-2013, 07:51 AM
zdawg8394's Avatar
yeah, it sounds like you have them already. shouldnt need any forms.
post #6 of 6 Old 04-15-2013, 07:56 AM Thread Starter
Not sure of the # it's at the house. I called h&s and asked them was the tuner with egr delete and dpf still available and they said they still had a few available that they were getting hard to come by. So I'm thinking i got one of the good ones. Guess I will find out when I hook it up. The book shows instructions for the hot damn tunes and some others for egr and dpf deletes
ajhester is offline
