Thermostat going out? - Ford Powerstroke Diesel Forum
post #1 of 9 Old 04-14-2013, 07:21 PM Thread Starter
Y&R0864's Avatar
Just seeing what the signs of a thermostat going out are?
My truck has just been running a little hotter than normal but delta has been fine for past few weeks. Running coolant 199 and oil 205 while driving 75 in about 80 degrees. Use to be cooler...
2008 F250 6.4 crew cab lariat w/s&b intake, flo pro egr delete, diamond eye 4" turbo back, and mini max
Y&R0864 is offline
post #2 of 9 Old 04-14-2013, 07:29 PM
bentstroke_02's Avatar
weather starting to warm up where your from?
Jeremiah
Horsepower is like sex, once you get it you can't get enough of it
2008 6.4 with 200k and counting
5" FLO-PRO exhaust W/6" tip
AFE stage 2 CAI
Spartan tuner
PTP EGR Delete
coolant filter
CCV Mod
leveling kit
4in rear Blocks
20's W/35's
bentstroke_02 is offline
post #3 of 9 Old 04-14-2013, 07:39 PM
ramonpowerstroker's Avatar
That's normal, mine ran at 200, and 209 in 90degree weather
ramonpowerstroker is offline
post #4 of 9 Old 04-14-2013, 09:31 PM Thread Starter
Y&R0864's Avatar
It's warming up but last year I didn't see much over 201 for oil.
Y&R0864 is offline
post #5 of 9 Old 04-15-2013, 06:43 PM
Its normal wants the weather starts warming up mine gets warm to but if it gets crazy start looking into it
Jeremiah
AFE stage 2 CAI
Spartan tuner
PTP EGR Delete
coolant filter
CCV Mod
leveling kit
4in rear Blocks
20's W/35's
post #6 of 9 Old 04-22-2013, 06:22 PM
Strokin & Smokin's Avatar
How about 183 degrees and takes forever for heat to kick on ??
'08 6.4 Fx4
85x miles
4" Straight pipe w/ duals
H&S Mini Maxx on Hott
S&B intake
Factory 20s
Jersey Strokers
Strokin & Smokin is offline
post #7 of 9 Old 04-23-2013, 07:00 AM
04hdfatboy's Avatar
Quoted: 4 Post(s)
^^ yes it sounds like your thermostat is bad.
08 F350 cc/sb 4X4
h&s minimaxx, 5" flo pro, 4" down pipe, no limit cold air intake, dirty diesel EGR delete with intake elbow, 6.0 exhaust manifolds, custom up pipes, ported intake manifold, Apex 71mm LP turbo, Rudy's cold side pipe, diesel site coolant and transmission filter, diesel site intercooler boots, ccv mod, bilstein shocks, gogo dd solenoid, HID lights, Airdog II 165, PMF traction bars, PMF drag link, moshimoto aluminum radiator
04hdfatboy is offline
post #8 of 9 Old 04-23-2013, 03:00 PM Thread Starter
Y&R0864's Avatar
Wait mine is goin out or smokin and strokin's is goin out?
Y&R0864 is offline
post #9 of 9 Old 04-23-2013, 03:01 PM
04hdfatboy's Avatar
Quoted: 4 Post(s)
Smokin and strokin's is going out. You temps seem fine.
08 F350 cc/sb 4X4
