Wrench Caution Light comes on - Ford Powerstroke Diesel Forum
post #1 of 5 Old 04-14-2013, 11:02 AM Thread Starter
Wrench Caution Light comes on periodically resulting reduction of power message and a caution light to reduce power. Two Ford Dealers have been unable to anything when they do the computer diagnostics, they have also told me that unless we bring it into the shop with the lights on THERE IS NOTHING THEY CAN DO TO HELP ME. I can not make the light come on at our will. If I stop and turn the engine off for 10 to 15 min. the light goes out and we can drive anywhere from 50 to 200 miles. I suspect that the exhaust cleaning (burning) cycle has not come on since this problem started 450 miles back. I am driving to Alaska (my home). HELP!!!! I will be taking it to another Ford Dealer on Monday. I have 2008 F-450 4X4 dully crew cab with a 6.4L Diesel and a 5 speed auto transmission. We are towing a 15000 lb. 5th wheel trailer.
bears38 is offline
post #2 of 5 Old 04-14-2013, 12:13 PM
Yeah it's a Turbo Diesel
mts678's Avatar
Quoted: 18 Post(s)
Feedback Score: 12 reviews
Do you have a tuner on it? Is your dpf and egr deleted or still on? If you have a tuner, have it scan for dtc's and see what codes it shows. Or if u don't have a tuner or code scanner, stop in any autozone and have them scan it for codes when the wrench light is on
Sent from AutoGuide.com App
2017 f250 platinum
Bone stock until warranty expires!
mts678 is online now
post #3 of 5 Old 04-15-2013, 06:01 AM
04hdfatboy's Avatar
Quoted: 4 Post(s)
I believe the wrench light means a drivetrain malfunction.
08 F350 cc/sb 4X4
h&s minimaxx, 5" flo pro, 4" down pipe, no limit cold air intake, dirty diesel EGR delete with intake elbow, 6.0 exhaust manifolds, custom up pipes, ported intake manifold, Apex 71mm LP turbo, Rudy's cold side pipe, diesel site coolant and transmission filter, diesel site intercooler boots, ccv mod, bilstein shocks, gogo dd solenoid, HID lights, Airdog II 165, PMF traction bars, PMF drag link, moshimoto aluminum radiator
04hdfatboy is offline
post #4 of 5 Old 04-19-2013, 10:23 AM
bigt2317's Avatar
When my wrench came on it was followed by a passive code (no check engine light but code was present). The code was for the oil temp and coolant temp deltas were too high which meant a clogged oil cooler.
Travis
2008 F350 King Ranch - A few fun things, Newton 2-1/2" leveling kit, HID headlights and fogs, 325/60 Hankook Dynapro ATM2's on stock 20" wheels, Firestone ride rite air bags, Air Lift wireless air controller, B&W gooseneck, Diesel site coolant filter, 30" LED bar
2005 Jeep Unlimited Rubicon - with some stuff
bigt2317 is offline
post #5 of 5 Old 04-26-2013, 04:07 PM
Powerstroke Happy's Avatar
I had the same thing happened to me. Wrench light came on. It threw a code that the dealer pulled up and I called for a malfunction of the fuel (lift) pump mounted to the frame rail. I was under warranty with mine and it went out at 47k. The code was P0232. I also had a reduction in power.
09 F-250 Lariat 6.4 Deeehezl
Crew Cab - 4x4 - Short Bed
Fully Loaded
Mods:
Dieselsite Coolant Filter
AFe Drop-in Replacement CAI Filter
H&S Mini MaxTuner HD300
Hollowed out DPF and CAT
4" Superlift (Front)
6" Icon 1pc Blocks (Rear)
Nitto Trail Grapplers:
LT325/60R20 (35.12 H x 12.91 W)
oh yeah, almost forgot...530 RWHP and 1050 TQ
Powerstroke Happy is offline
