Transmission fluid change - Ford Powerstroke Diesel Forum
post #1 of 10 Old 04-12-2013, 03:54 AM Thread Starter
Served Our Country!
CrazyCowboy's Avatar
Quoted: 3 Post(s)
Looking for some advice when I change the filter in my pan and part of the transmission fluid tomorrow morning. What is the general opinion concerning changing the fluid when the truck has set overnight, or running the truck for a while and getting the fluid warm before the change.I know there would be more fluid in the pan if the truck has sat for a while, but does the fluid need to be warm first. Also, it is my understanding that I will need about eight to nine quarts does this sound correct to you guys? Thanks in advance for any advice.
CrazyCowboy is offline
post #2 of 10 Old 04-12-2013, 04:46 AM
travisH3's Avatar
Quoted: 2 Post(s)
Feedback Score: 13 reviews
mine took 10 quarts. Make sure the trans is up to temp and in nuetral to check fluid level. Nothing really special about changing it. I warmed mine up then Drain fluid, drop pan. then you want to pull the filter cartridge straight down with CAUTION. It goes everywhere. The little rubber ring around that filter was stuck up there. Had to use a small hook to pull it down. its a orangish/salmon colored metal ring coated in rubber so the whole metal piece needs to come out not just the rubber coating. Mine was stuck pretty good. Once ya do that ya replace the filter and install the pan using the old gasket(its reusible but i bought a new one because my trans was leaking around that seal) start all bolts before tightening them so it tightens down flat doing a few turns at a time on all bolts. refill with atleast 9 quarts of fluid. after checking mine it needed another quart. Only issue you may run into is the very back of the pan has a 3 or 4 bolts are under the tranny cross member and you need a swivel to get on them. other than that its gonna be straight forward. PS....the magnet is gonna have a ton of mucky shavings on it. Pull the magnet off of the bottom of the pan and clean all shaving out really good with a towel that wont leave fibers behind
T-rav
2010 F350 6.4-
s467 MPD single kit, H&S Jesse Byall tuning, No limit IC piping and intake,mishimoto intercooler, MPD billet CCV/oil filler, FASS with sump, SOTA A.W.O.L. polished wheels, toyo rt tires, RED Newton traction bars, oem projector retrofit and a bunch of LED lights LOL
Holderdown Performance #teamHDP
OUR FLEET: 2015 f450, 2014 Platinum F350, 2012 F450 6.7, 2010 F350 6.4, 2005 F350 6.0, 04 F450 6.0
travisH3 is offline
post #3 of 10 Old 04-12-2013, 06:17 AM Thread Starter
Served Our Country!
Quoted: 3 Post(s)
Thanks I appreciate the help.
post #4 of 10 Old 04-12-2013, 06:31 AM
NVHunter83's Avatar
What type of tranny fluid are we suppose to use?
2008 Ford F-350
6.4L Power Stroke
Crew Cab Long Bed
Buck Stop Bumper w/
WARN 9500 lbs. Winch
H&S Mini Maxx w/ homemade mount
5" Flo-Pro DPB exhaust w/ muffler
Bilstein 5100s Shocks
AFe Stage II Magnum Force Intake
NVHunter83 is offline
post #5 of 10 Old 04-12-2013, 06:35 AM Thread Starter
Served Our Country!
Quoted: 3 Post(s)
Mercon LV is the latest version.
post #6 of 10 Old 04-12-2013, 10:45 PM
Clayton1985's Avatar
Yeah use the LV. Travis pretty much summed it up. I changed my trans temp sensor this winter (-30c in the driveway, real fun) and changed filter while I was in there. I did it cold. Took just under 10qts to re-fill.
2008 Job 3, F350, 6.4/drw/lariat/CC/LB, Spartan, Viper 5902, Line-X, Flo-pro egr delete, aFe stage 2 proguard 7, MBRP Cool Duals/downpipe/CAC, CCV mod, coolant filter PMF 7" 4link, Rigid Dually fogs, Royalty Core 3pc, Crown brake lines, Mishimoto Rad
6.4 Rebuild May/2015, BD manifolds+Uppipes, chromoly rods, rockers,lifters, hd springs
Monstir 20", 37x12.50 ATZ P3
1999 Corvette Cpe
Clayton1985 is offline
post #7 of 10 Old 08-04-2014, 09:04 PM
pls help i changed my tranny filters added 9/1/2 qrts and now cold seems to read high like it will even drip if i tilt it but when up too temp it reads perfect pls help i dont wanna ruin my tranny thnxs
dsf350 is offline
post #8 of 10 Old 08-04-2014, 09:12 PM
snobdds's Avatar
Quoted: 9 Post(s)
As long as it reads correct when warm and in neutral, your fine.
snobdds is offline
post #9 of 10 Old 08-04-2014, 09:43 PM
ok thank you i was just worried bout ruining my tranny
dsf350 is offline
post #10 of 10 Old 08-04-2014, 09:49 PM
do u think i should drain some
dsf350 is offline
