Pumped gasoline instead of diesel.... - Ford Powerstroke Diesel Forum
post #1 of 28 Old 04-11-2013, 08:57 AM Thread Starter
Redz284u's Avatar
Quoted: 9 Post(s)
So my son put premium unleaded instead of diesel.........WTF. The station by our house has green label for premium unleaded and that's what he put. I'm so pist I could @"$)(;:*^%#}{_\~€ŁĄ•. More so I'm post at myself. I should have not let him. I know it's just a car, but he freakin 20 years old. Too old for this type of mistake if u ask me. Sorry guys just a little frustrated here.
Anyways what now. I drained the tank. Put half tank with 20 oz of diesel kleen. Started up and no strange noises. He only drove about 7-10 miles.
Redz284u is offline
post #2 of 28 Old 04-11-2013, 09:13 AM
SuperCrutyPS's Avatar
Quoted: 297 Post(s)
Garage
Sorry to hear that. Hopefully, you caught it before it did anything.
I think fueling places need to standardize their labeling or handles to help avoid confusion. One company does it this way, another does it that way
Owner | Operator: Darryl
My Truck Garage:
Tow Toy Garage :
United States Navy - IC2 - '76-'80
SuperCrutyPS is offline
post #3 of 28 Old 04-11-2013, 09:17 AM
2000-7.3L's Avatar
Feedback Score: 10 reviews
hOW DID YOU FIND OUT HE PUT GAS INSTEAD OF DIESEL?
2000-7.3L is offline
post #4 of 28 Old 04-11-2013, 09:37 AM Thread Starter
Redz284u's Avatar
Quoted: 9 Post(s)
I thought it was bad diesel with maybe some water in it. So I drained it from the water separator. Looked and smelt it. Then the yelling started........
Redz284u is offline
post #5 of 28 Old 04-11-2013, 09:40 AM
2000-7.3L's Avatar
Yupp my old man would have done the same thing...still does LOL,
Drain tank, flush fuel lines, replce fuel filters!
post #6 of 28 Old 04-11-2013, 09:43 AM Thread Starter
Redz284u's Avatar
Quoted: 9 Post(s)
What kind I damage is expected? What do I look/listen for? What are the signs and confirmation i'm screwed?
Redz284u is offline
post #7 of 28 Old 04-11-2013, 09:48 AM
2000-7.3L's Avatar
When it doesnt start!
Do all those things listed above and should be fine! As long as you didnt go a long distance with it! Cats might have clogged?
post #8 of 28 Old 04-11-2013, 09:55 AM
Hunter of Trolls
drewactual's Avatar
Quoted: 57 Post(s)
after the rail is the injectors, and that is about the end of the line for fuel.... with that in mind, I'd flush the HADES out of it, with the FRP Sensor out (which is on the passenger side fuel rail, over cylinder 2) or with the return banjo wide open..
that HMFC pump is handy in it's configuration in this case.. I'd pull the HPFP feed line off of it and pump the tank dry (but you've already drained and replaced, no?).. Fill it w/ some good clean diesel (at least five gallons).. swap out all fuel filters... open the banjo (or pull the FRP sensor, which may be overkill).. and force clean diesel through the entire fuel delivery system just short of the injectors...
Once I was satisfied that it was flushed, I'd replace filters again, button everything up, prime the system, and hope for the best...
http://www.backglass.org/duncan/ps64...ply_System.pdf
drewactual is offline
post #9 of 28 Old 04-11-2013, 09:55 AM Thread Starter
Redz284u's Avatar
Quoted: 9 Post(s)
So no white smoke, no backfiring, no rough idle or driving? At some point it just won't start? I should mention I drive the truck to work today. 45 miles babying it. No smoke, no wierd noises. I filled with 16 gal fresh diesel, added 16 oz of diesel kleen. Bled the water separator under driver side. On way home will stop by and get filters and replace ASAP.
Redz284u is offline
post #10 of 28 Old 04-11-2013, 09:57 AM
Mod Newbie
dhanna6powerstroke's Avatar
Quoted: 19 Post(s)
Gasoline will junk the injectors and HPFP just like too much water will. Hopefully that didn't happen though. Just out of curiosity, does your son drive a diesel on a regular basis?
dhanna6powerstroke is offline
