Info - Ford Powerstroke Diesel Forum
post #1 of 8 Old 04-08-2013, 09:52 AM Thread Starter
Info
Info
Ok I'm new to the powerstrokes. So if I buy a h&s programmer how much more money will I have to spend to do the egr and PDF delete. And I guess the programmer needs to be able to do those deletes right. Any info is helpful. Thanks
ajhester is offline
post #2 of 8 Old 04-08-2013, 10:12 AM
superduty6.4's Avatar
The egr delete is probably around 250 ( you may be able to find one a bit cheaper ), the delete depending on which way you go would be probably under 200 for just a delete pipe and maybe around 4-500 for a dp back exhaust. This would be just the parts and doing it yourself. Labour of a shop doing the work would obviously add a bit to the cost.
08 F350 JOB 1
H&S MINI MAXX HD300 W/S1M
SINISTER EGR/COOLER DELETE
6000K BEAMERS HID HEAD & FOGLIGHTS
KMC XD WHEELS W/NITTO TRAIL GRAPPLERS
2.5" LEVELING KIT
DIESELSITE COOLANT FILTER
ROTELLA EC-1 RATED COOLANT
5" DP BACK FLO-PRO EXHAUST
FLO-PRO CAC PIPE & INTAKE ELBOW
CCV MOD
AIR LIFT 5000LB AIR BAGS W/ONBOARD COMPRESSOR
AFE CAI
PMF TRACTION BARS
superduty6.4 is offline
post #3 of 8 Old 04-08-2013, 11:24 AM Thread Starter
Ok thanks. Is the h&s mini max the best
ajhester is offline
post #4 of 8 Old 04-08-2013, 12:40 PM
I can't compare it to anything except an edge evolution and it is definitely a better tuner than the edge, although I did use the edge for 35,000 trouble free kms. There are a ton of people also using spartans which is a very popular option as well, I would say the same popularity as h&s. They both seem to make top notch products so it just depends on which options appeal to you. You won't go wrong with either.
08 F350 JOB 1
2.5" LEVELING KIT
CCV MOD
AFE CAI
PMF TRACTION BARS
post #5 of 8 Old 04-09-2013, 04:38 AM
Fueling M.A.D. Everywhere
CountryAggie's Avatar
Spartan or H&S or SCT with custom (ie gearhead or innovative tunes).
Just make sure with the H&S you get the race version. Not the 'street' version.
Sent from AutoGuide.com App
-Tyler
Texas A&M c/o 2010
CountryAggie is offline
post #6 of 8 Old 04-09-2013, 10:01 AM
If you buy a used H&S Race what are the costs to have it reprogrammed?
Specifically IF the prior owner removed the tune before getting rid of the truck? and IF they didn't?
seafordguy is offline
post #7 of 8 Old 04-09-2013, 10:21 AM
05_PSD_Erik's Avatar
Info
If you purchased an H&S RACE tuner, then yes the tuner will support a delete. If you bought the H&S Street tuner, no it won;t delete.
H&S will not unlock any of the race tuners. If you buy a used race tuner, make 100% sure it is unlocked from the previous vehicle, otherwise, you have a pretty paperweight...
2009 Subaru WRX Premium
Type RS BOV
CAI
Muffler Delete
Had to park it with some real diesel muscle....
05_PSD_Erik is offline
post #8 of 8 Old 04-09-2013, 05:10 PM Thread Starter
Ok thanks a lot the guys at Rudy's diesel are shipping me my stuff today.
ajhester is offline
