Castor adjustment, What are you using? - Ford Powerstroke Diesel Forum
post #1 of 9 Old 04-07-2013, 09:38 PM Thread Starter
44magnum's Avatar
So I'm looking to add some castor to my truck, and I'm having a hard time convincing my self to buy PMF's 4 link setup. So I ask, what are you guys doing to add some castor to your truck? The only kit I found for our trucks is the BD kit. And If I'm going to spend that much I might as well just bite the bullet and get the 4 link from Trevor. Reviews on any of these would be appreciated.
BD Power - Product: Cam Caster Adjuster Kit
HD Long Arm 4-Link Kit
2008 (Job 1) F250 King ranch 4x4, snow plow prep package with 2.5 level. Black Maxx, B&W Diehard platinums. Dieselsite coolant and transmission filters, NCU Motorsports/amsoil oil bypass kit. Turbo blankets, 5.5 PMF traction
Please collect and message me Shell, Rotella oil cap codes aka "my miles matter" I'm trying to save up for a hat or something.
44magnum is offline
post #2 of 9 Old 04-08-2013, 07:36 AM
04hdfatboy's Avatar
Quoted: 4 Post(s)
I cant really help you with your question because i dont know. I do know that trevor's products are top notch and you wont be disappointed if you go with them.
08 F350 cc/sb 4X4
h&s minimaxx, 5" flo pro, 4" down pipe, no limit cold air intake, dirty diesel EGR delete with intake elbow, 6.0 exhaust manifolds, custom up pipes, ported intake manifold, Apex 71mm LP turbo, Rudy's cold side pipe, diesel site coolant and transmission filter, diesel site intercooler boots, ccv mod, bilstein shocks, gogo dd solenoid, HID lights, Airdog II 165, PMF traction bars, PMF drag link, moshimoto aluminum radiator
04hdfatboy is offline
post #3 of 9 Old 04-08-2013, 08:41 AM
Skyd Ram's Avatar
Quoted: 121 Post(s)
How much lift is on your truck and are you running caster cams at the moment?
Carli Suspension | Pure Performance Suspension | Bilstein Shocks | Fox Shocks
Dynatrac | Flo Pro Exhaust| aFe Power | S&B | BMF | Fuel | Air Dog | Amp Research
Trailready Wheels | Spicer | ARP | REV-X | RIGID Industries | KD Fabworks | Baja Designs
888-886-2480
Skyd Ram is offline
post #4 of 9 Old 04-08-2013, 10:11 AM
NotStock's Avatar
If you arent currently running them, you may consider using alignment cams in the upper balljoints. You can gain about 1*. I wouldnt go over that with alignment cams though.
Precision Metal Fab
Trevor Hall
(520)465-7971
NotStock is offline
post #5 of 9 Old 04-08-2013, 12:12 PM
Quoted: 3 Post(s)
Feedback Score: 5 reviews
Their is NOTHING wrong with using 2.5* cams on the balljoints...
CT Performance, Inc. is offline
post #6 of 9 Old 04-08-2013, 01:14 PM Thread Starter
44magnum's Avatar
I just have a leveling kit (3")and I forget what my castor is right now but I hear upwards of 5* is ideal. I'll have to look into the ball joints.
44magnum is offline
post #7 of 9 Old 04-08-2013, 03:11 PM
WoodBoy's Avatar
I think you want 3.0-4.0 of caster right?
44magnum, Im not trying to steal your thread, but maybe when they answer your question they can answer this.
Does anyone know how much caster should be added per 1" of leveling?
I would like to add some caster to mine too as I run 2.5" in the front
2010 CC/SB FX4 Lariat.. Tuned By Eric@IDP and Matt@Gearhead
Thinking about getting rid of the stock 6.7 turbo?
Check this out... and research before buying
WoodBoy is offline
post #8 of 9 Old 04-08-2013, 03:22 PM
Quoted: 3 Post(s)
You want all you can get..4.5-5* is the goal but you won't get there with just castor shims.
post #9 of 9 Old 04-08-2013, 07:00 PM
wired1's Avatar
I am using pmf 3 link and I was able to set my caster at 4.75R and 4.25L I could of had a bigger split but the roads out here suck for crowning so .5 deg split works pretty good for me.
Another option is pmf new 2.5" drop radius arm brackets seeing how you have a leveling kit and add some caster cams. That wont get you into the 4 deg + range but it will improve caster from where you are now.
2013 F150 FX4 EcoBoost fully loaded with the app pkg on Icon 2.5" coilovers
06 F350 Lariat-PMF 8" on 37'sSold
09 F350 ccsb Pmf 7" on 37's Sold
01 F250 ccsb 6" on 35's with to much to list Sold
98 Cobra Vert 583 RWHP Sold
wired1 is offline
