Just went through Arizona Emissions - Ford Powerstroke Diesel Forum
post #1 of 12 Old 04-04-2013, 08:09 PM Thread Starter
Quoted: 2 Post(s)
Took truck through emissions for first time today. Truck is all stock and blew a .5 out of allowable 40. First time I ever did snap test holding throttle to the floor for 3 seconds. Emission guys cracked me up when they popped hood and said damn " 10 lbs of $hit in a 5 lb bag. My truck was the first one they had tested since it was exempt first 5 years.
Asked them what they were looking at during inspection. They said they had to check CCV and CAT. didn't even look at EGR or seem to care about DPF.
Blue Turd is offline
post #2 of 12 Old 04-05-2013, 07:00 AM
WoodBoy's Avatar
Did they plug anything to your OBD port
2010 CC/SB FX4 Lariat.. Tuned By Eric@IDP and Matt@Gearhead
Thinking about getting rid of the stock 6.7 turbo?
Check this out... and research before buying
WoodBoy is offline
post #3 of 12 Old 04-05-2013, 12:05 PM Thread Starter
Quoted: 2 Post(s)
No. I didnt even get out of the truck
post #4 of 12 Old 04-05-2013, 02:06 PM
Couch warmer
SchismX's Avatar
Are you deleted? I live in AZ as well, so just curious.
08 F-350 CCSB - H&S Mini Maxx, 5" MBRP straight piped and 3" CAC pipe, Flo-Pro full EGR delete, Spearco IC, AFE STG 2 CAI
SchismX is offline
post #5 of 12 Old 04-05-2013, 04:34 PM
WydOpen's Avatar
Send a message via AIM to WydOpen
Sub'ing...curious to know if you're deleted as well in Arizona.
- Rob
2015 Tuxedo Black F250 CCSB Platinum FX4 6.7L PSD
PMF 2.5" Alpha Series | Fuel 22x10 Mavericks | Nitto 325/50-22 Trails | Edge CTS2 | AMP PowerSteps | RetroShop Headlights
WydOpen is offline
post #6 of 12 Old 04-05-2013, 08:15 PM Thread Starter
Quoted: 2 Post(s)
I am not deleted. Thought you guys might want to know how test went.
Pulled up, gave them my ticket. They checked vin in the door then told me how test was going to be performed. Wanted me to floor truck for aprox 3 seconds until screen changed colors. Basically hold it to the floor and let it bounce off the rev limiter. They put sniffer behind my exhaust and performed actual test. Only had to bounce it off the rev limiter once.
Then they pressure tested fuel tank or cap. Couldn't tell cuz I had Morris folded in and was watching guys under the hood. They didn't know what they were looking at. We're looking for a sticker on motor then fiddled around near drivers side firewall. Another guy stuck mirror under truck and told other guy it had a cat. Didn't seem to care or even notice DPF
I asked guy what they look for on visual and he said CCV and cat. Truck blew a .5 and allowed 40
Not sure what our standards are compared to other diesels. Wonder if a tuned truck could go through only cracking throttle 3/4 open. They didn't scan and didn't seem to care about dpf.
Guess you could put back stock and pass for 2 years
post #7 of 12 Old 04-05-2013, 08:39 PM
WoodBoy's Avatar
I am curious to know what the numbers would be if the truck would have been in regen
WoodBoy is offline
post #8 of 12 Old 04-05-2013, 08:55 PM
i hope Texas never goes to these types of inspections i think half the state would be in trouble . but now im curious of what a deleted truck would blow
]2011 f250 king ranch cc/sb fx4 black and tan allot of inferior parts fell off so i put better ones on . 5inch exhaust axle dump s7b intake . blistien 5100s all the around . 20x12s on 305,55,20s .leveling kit with bags in the rear .5% tint all the way around
lhood6.7 is offline
post #9 of 12 Old 04-05-2013, 09:44 PM
Fueling M.A.D. Everywhere
CountryAggie's Avatar
I'm willing to bet a lot more than half...
I wonder what they are checking with the CCV?
Sent from AutoGuide.com App
-Tyler
Texas A&M c/o 2010
CountryAggie is offline
post #10 of 12 Old 04-06-2013, 06:42 AM
Slacker
Evil Eye's Avatar
Quoted: 204 Post(s)
Feedback Score: 4 reviews
I have noticed that when I first started having to do emissions, half the time they didn't know what to check for. My last test (in February) they checked for everything (EGR, CCV, matching VIN's, etc) and this is the first time they checked for the CCV. (For those that are asking about CCV, they are ensuring that it is hooked up and not evacuating to the atmosphere.) Based on my results, they will continue to get better at knowing what to look for. Also, our emissions tests have to be done annually so they are only good for one year.
***Edit: Just wanted to mention that I have a 6.0 so it's been tested for several years now***
Shawn Carlson
Proud Navy Vet
2005 F250, CCSB, 6.0 PSD, FX4 (The Sweet Unit is white)
2008 F350, CCLB, 6.4 PSD (Brad-the wife's truck is black)
Engine Mods:
Fluidampr
CCV Reroute (Reinstated)
4" MBRP Exhaust
MTW Stage 1 Turbo
Bulletproof 53V FICM
BulletProof EGR Cooler
BulletProof Water Pump
Riff Raff Intercooler Boots
Gogo Diesel Direct Drive Solenoid
BulletProof All-Aluminum Radiator
BulletProof All-Aluminum Intercooler
BulletProof Oil Cooler System w/ Bypass Filter
SCT w/ Custom Tunes (TSD, DJ's, Innovative, Gearhead, QuickTricks)
Exterior Mods:
Bilstein 5100 Shocks
Icon Adjustable Trac Bar
Firestone RideRite Air Bags
BDS Dual Steering Stabilizer
Aluminum Finned Differential Cover
Reese 16k Manual Slider 5th Wheel Hitch
Icon 2.5" Leveling Kit w/ F-350 rear blocks
20" BMF Novakanes wrapped in 33" Nitto Terra Grapplers
Evil Eye is offline
