Couple random questions - Ford Powerstroke Diesel Forum
post #1 of 10 Old 04-03-2013, 06:16 PM Thread Starter
1.)What have you guys found to be the best tires for mostly on road driving and approximately how many miles are you getting from them?
2.) I was thinking of doing a 6 inch lift and found that the highest i can go would be 37's? Also if anyone has 22" wheels with a 6 inch lift and can post a picture that be awesome.
3.) This ones simple when the truck is "Cleaning Exhaust Filter" is that the regen process?
Mmace111 is offline
post #2 of 10 Old 04-03-2013, 07:05 PM
ramonpowerstroker's Avatar
#3 is yes
ramonpowerstroker is offline
post #3 of 10 Old 04-03-2013, 07:09 PM Thread Starter
lol okay one down
Mmace111 is offline
post #4 of 10 Old 04-04-2013, 06:54 AM
Delete your truck if you can, and you will not see that message again. Not to mention it will help your fuel economy and add some reliability to the truck.
2010 Ford F-250 Super Duty, Lariet 4x4, Crew Cab Short Bed, loaded with every option...and more
turbo kidd is offline
post #5 of 10 Old 04-04-2013, 07:11 AM
Hunter of Trolls
drewactual's Avatar
Quoted: 57 Post(s)
mostly on-road? convoluted question...
for 100% on road, nitto dura grapplers.. you should see 70k miles out of them..
for 'mostly' on road, as in 70+%, cooper at+3's floggin' rock.. you should see 40K out of them.. nitto terra grapplers are a good second choice, with about the same mileage expectations, just a touch less grip off-road (around here, anyway)..
if you're looking to lift and have an aggressive looking tire with good road manners, dick cepek fun country II radials are hard to beat.. mickyT's have the exact same casing (made by same folks), but a little wider lugs than the fc's.. they seem to wear as good or better than the fc's on the road, but don't grip as well off.. you should get 30~35k miles out of either tire if they are well balanced, rotated, and you have a good alignment.. and good bearings.. for the love of God keep your bearings in check when running a big heavy tire- I ate through a front pair of FC's in about 10k miles because of bearings.. dang it..
just my $0.02..
drewactual is offline
post #6 of 10 Old 04-04-2013, 08:14 AM
WydOpen's Avatar
Send a message via AIM to WydOpen
Search some of my recent posts for pics with 6" lift and 22's. Good combo IMO, I'm very happy with the look. I've run both 35's and 37's and kind of on the fence as to which I like better.
- Rob
2015 Tuxedo Black F250 CCSB Platinum FX4 6.7L PSD
PMF 2.5" Alpha Series | Fuel 22x10 Mavericks | Nitto 325/50-22 Trails | Edge CTS2 | AMP PowerSteps | RetroShop Headlights
WydOpen is offline
post #7 of 10 Old 04-04-2013, 05:21 PM Thread Starter
awesome thanks alot guys lot of help!
Mmace111 is offline
post #8 of 10 Old 04-04-2013, 08:10 PM
floorboy's Avatar
Hmmm. I have put 2500 miles on andnever seen that message and I'm stock. (Till Tuesday )
Originally Posted by bjs505 View Post
Of course I'm handy under the hood, I currently own a cummins.
2010 F350 CCLB Cabelas Edition
No Limit cai, Mini Maxx, 5" turbo back Flo Pro, Sinister egr delete, Sinister coolant filter, Cat EC-1, PTP shift solenoid. 20x9 +18 XD Monsters
01' 7.3 CCLB, 6637,wicked wheel G2, HPX, PHP Hydra, MBRP 4" Turbo back, Bellowed uppipes, Stancor gpr, 6.0 cooler, Fpr, Glow shift exhaust, pyro, trans, 203*/billet housing/ Cat EC-1, '07headlights/05' grill, Oh8' gate.
78' F350 "dumpy" old school
floorboy is offline
post #9 of 10 Old 04-04-2013, 08:38 PM Thread Starter
It happens its part of the regen process, the message doesnt just pop up if you go to system check itll be the last thing that shows, and it only lasts for ike 15 minutes,you can tell when its happening barely though your truck will kind of run a little different for that short period of time
Mmace111 is offline
post #10 of 10 Old 04-05-2013, 09:55 PM
Fueling M.A.D. Everywhere
CountryAggie's Avatar
The message does pop up every time. It use to stay up the entire time until one of the most recent reflashes. Now it only stays on at the beginning for a few seconds. But it does show up every Regen, I bet you just miss it most times.
Sent from AutoGuide.com App
-Tyler
Texas A&M c/o 2010
CountryAggie is offline
