Need 08 Leveling Kit Info - Ford Powerstroke Diesel Forum
post #1 of 5 Old 04-03-2013, 11:48 AM Thread Starter
Hillbilly Deluxe
STROKED_NY_023's Avatar
Quoted: 2 Post(s)
Feedback Score: 3 reviews
Need some info from you guys that have leveling kits.
My soon to begin project involves swapping 08 SD axles under an OBS truck. I plan on running 35" tires and recently purchased a leveling kit from a member here. I didnt realize at the time (and didnt ask either, no hard feelings at all) that the kit was one that got installed on the BOTTOM of the coil.
Has or is anyone using this type of kit?? Its a skyjacker 2" front, 1"rear kit...
Any info would be great...
_____________________________________________
Seth
Stroked_NY_023
95' F-350 CCLB DRW POWERSTROKE
08 Axle/4x4 conversion, 5spd conversion, 6637, 5" SP exhaust, gearhead tunes
STROKED_NY_023 is offline
post #2 of 5 Old 04-03-2013, 03:21 PM
44magnum's Avatar
Quoted: 2 Post(s)
Ya I have an under coil spacer. they seem pretty common with the 08-10 trucks. as far as I can tell there isn't any real difference between the under and above coil spacers.
[FONT=Verdana][I][B][SIZE=2]2008 (Job 1) F250 King ranch 4x4, snow plow prep package with 2.5 level. Black Maxx, B&W Diehard platinums. Dieselsite coolant and transmission filters, NCU Motorsports/amsoil oil bypass kit. Turbo blankets, 5.5" blocks & PMF "floating" traction bars
44magnum is offline
post #3 of 5 Old 04-04-2013, 05:39 PM Thread Starter
Hillbilly Deluxe
Quoted: 2 Post(s)
Thanks for the info... Still trying to decide if I want to use them. Easy to install?
Sent from AutoGuide.com App
Seth
Stroked_NY_023
post #4 of 5 Old 04-04-2013, 07:26 PM
44magnum's Avatar
Quoted: 2 Post(s)
Ya they are easy to install.
I'm curious, what's giving you pause about your kit?
44magnum is offline
post #5 of 5 Old 04-05-2013, 07:57 AM Thread Starter
Hillbilly Deluxe
Quoted: 2 Post(s)
Idk... Read a couple threads where they were saying to stay away from thwt type, juwt every other kit I looking looked at had the spacers on top of the coil. I will probably and up running it though.
Seth
Stroked_NY_023
