Bad Head Gaskets? - Ford Powerstroke Diesel Forum
post #1 of 15 Old 04-02-2013, 08:18 AM Thread Starter
PetersMatt7's Avatar
Bad Head Gaskets?
Hi i drive an 08 6.4 with just the bolt ons and a mini max and recently i began to notice my degas bottle burping coolant out of the cap so i put a new stant cap on. From what I've read people are saying when this typically happens head gaskets are bad, but I have no clue how to tell for sure whether or not my gaskets are bad. I plan on building my motor here very soon so head studs will be a must but for the time being i really don't wanna screw anything up!http://www.powerstroke.org/forum/ima.../thankyou2.gif
PetersMatt7 is offline
post #2 of 15 Old 04-02-2013, 08:25 AM
I have the same mods.. Just the bolt on stuff.. I puked from my cap, I put it back to stock and brought to the dealer since I still have warranty.. They said there is a new design out for the cap and degas bottle, so they changed it all out, and tested the coolant for gases which was negative and also did a pressure test and was normal.. So It could just be your cap, only way to really tell if just drive you truck how you did the first time it puked to see if it does it again.. I thought it was my gaskets, but I have drove my truck pretty hard and I haven't seen any coolant leak and I haven't noticed a lose in coolant either
Jimbo33 is offline
post #3 of 15 Old 04-02-2013, 08:29 AM Thread Starter
I drove it pretty hard on a mild tune and it still puked.
post #4 of 15 Old 04-02-2013, 09:16 AM
srjd's Avatar
Quoted: 2 Post(s)
Sorry to say it Peter but most likely your gaskets are going. Only a few lucky buggers are lucky e ought to get away with just replacing the cap. Just take it in and get pressure tested I wish I did that but instead I changed about 4 caps and a bunch of other things. Mine went on a mild tune and I drive very conservative.
01/07 Job 1 F350 H&S Tuned. ARP Studs, AFE 4'' straight pipe, EGR delete with elbow, AFE stage 2 CAI, 6'' lift on 37s, 20x12 Fuel Nuts two piece, Sinister coolant filter, CCV Mod, Projector headlights HID kit
srjd is offline
post #5 of 15 Old 04-02-2013, 12:22 PM Thread Starter
Thank you for the help! Sometimes these trucks are harder to read than women!
post #6 of 15 Old 04-02-2013, 12:26 PM
srjd's Avatar
Quoted: 2 Post(s)
You got that right!!! Either way get it pressure tested and that will most likely give you your answer
srjd is offline
post #7 of 15 Old 04-02-2013, 05:42 PM
tkobes43's Avatar
Quoted: 2 Post(s)
Garage
Best of luck! Hope you still got the warranty!
Tom
5" MBRP Straight Exhaust w/ 6" tip, SCT Monitored, Limo Tints, 20" LED Lightbar, 8k HIDS, & Some other goodies
Other Rides
1978 Trans Am Y88 403 84k original miles
1996 Ford F350 PSD Mason Dump 134k Original Miles!
Gone But Not Forgotten... (Lilah) 2008 Ford F250 Lariat CrewCab
Proud To Be An American!
tkobes43 is offline
post #8 of 15 Old 04-02-2013, 07:11 PM
I think he meant for you to replace the coolant cap and THEN drive it to see if it still puked. Just making sure you got that part....
2010 F350 Lariat, Ready Lift 2.5" level kit, Toyo Open Country AT2-35 x 12.5 R20 on Worx Tyrant rims
sugelle is offline
post #9 of 15 Old 04-03-2013, 07:14 AM
Hope it works out for you. Let us know what the results are.
30-378 is offline
post #10 of 15 Old 04-03-2013, 07:39 AM Thread Starter
Haha yes i got the new cap last week and it still puked! No warranty, but she will go under the knife here shortly.
