Lifted trucks oil temps? - Ford Powerstroke Diesel Forum
post #1 of 7 Old 03-31-2013, 07:53 PM Thread Starter
Y&R0864's Avatar
Just curious what others with lifts are getting for oil and coolant temps now that summer is around the corner.
I've been getting 199 coolant and 205 oil. Just trying to get an idea of what is normal. And I'm in central Texas. It's been around 80 here lately in the heat of the day.
2008 F250 6.4 crew cab lariat w/s&b intake, flo pro egr delete, diamond eye 4" turbo back, and mini max
Y&R0864 is offline
post #2 of 7 Old 03-31-2013, 07:59 PM
CFoster's Avatar
190 coolant 192 oil been around 60 here.
F250 CCSB FX4
Spartan dashdaq
,deleted,RCX 4-link 6" Lift, 325/60R20 Goodyear Duratracs, 20x10 Gear wheels, 15% tint,RBP step bars.
CFoster is offline
post #3 of 7 Old 04-01-2013, 05:40 AM Thread Starter
Y&R0864's Avatar
Yea your truck is running a bit cooler than mine. I wonder if a coolant filter can cause that.
Y&R0864 is offline
post #4 of 7 Old 04-01-2013, 09:19 AM
srjd's Avatar
Quoted: 2 Post(s)
My lift didn't change my temps and coolant filter didn't change them. In the winter I run 188-190 coolant and 194ish and in the summer I run 194 coolant and 199 oil
01/07 Job 1 F350 H&S Tuned. ARP Studs, AFE 4'' straight pipe, EGR delete with elbow, AFE stage 2 CAI, 6'' lift on 37s, 20x12 Fuel Nuts two piece, Sinister coolant filter, CCV Mod, Projector headlights HID kit
srjd is offline
post #5 of 7 Old 04-01-2013, 09:25 AM
srjd's Avatar
Quoted: 2 Post(s)
Lots of different things factor into those temps. I should mention I have seen the temps your seeing as well. Your delta looks good I really wouldn't worry about it unless it goes higher. Could be the humidity or a head wind could be anything
srjd is offline
post #6 of 7 Old 04-01-2013, 05:48 PM Thread Starter
Y&R0864's Avatar
Well thanks for the piece of mind. I just wasn't crazy about that 205 oil temp... Other than that, around town and down county roads is all good.
Y&R0864 is offline
post #7 of 7 Old 04-01-2013, 08:42 PM
F450Harley's Avatar
199 coolant , 204 oil @75 mph. When idling or stopped they do drop a few degrees. Outside temps been mostly 75-80* (highs)
F450Harley is offline
