P2262, no boost code, truck runs normal - Ford Powerstroke Diesel Forum
post #1 of 2 Old 03-31-2013, 02:31 PM Thread Starter
Hi guys, I have a 2005 F250, CE light came on a couple days ago, P2262, no boost, mechanical. My factory gage shows boost, I also have an aftermarket gage that reads the same, truck performs normal, the code will not clear. Truck has an SCT custom programmer for towing, MBRP exhaust and EGR delete kit, but all these changes have been there for at least 2 years with no issues so I do not think they are related.
I have read some about the MAP, should I start there? simple and cheap?
I am an automotive tech, but I do not specialize in diesels and this is the first issue I have had with this truck in years. I would like some help from you experts on where to go with this since I have no symptoms.
thank you in advance.
jrscars is offline
post #2 of 2 Old 03-31-2013, 02:47 PM
Quoted: 2 Post(s)
you're in the 6.4 section.. a Mod will probably move this for you, but i would try posting in the 6.0 section
Kris
2008 Ford F250 6.4L Crew Cab Short Bed King Ranch
3.5" ReadyLift Leveling Kit, 37x13.5x20 Toyo MT's on stock 20's, Dual Steering Stabilizer, Livewire w/ IDP, KEM, Gearhead, S&B, 5" Flo-Pro, Rudy's EGR Delete and Cold Side Pipe, CCV
p8ntballn2 is offline
