Changed Oil - Broke plastic thingy inside housing.... - Ford Powerstroke Diesel Forum
post #1 of 13 Old 03-31-2013, 01:04 PM Thread Starter
KVB-R's Avatar
Is this really bad?
I purchased a Fram filter and when I went to slide it inside the housing, it wouldn't depress the little plunger inside the big spring tube. So I was f'ing with and the plastic bit and the little spring flew out.
All I know is that the little plunger releases the big spring so one can slide the filter all the way down??? Is there anything else that thing does?
Please let me know before I waste an engine.
Thanks,
Kevin
Spartan'd, 4" ICON Stage II, 35" Duratracs, XPD additive and M1 full synthetic
KVB-R is offline
post #2 of 13 Old 03-31-2013, 01:17 PM
Quoted: 2 Post(s)
are you talking about the plunger and spring in the oil filter housing? or the tabs under the filter cap?
for future reference, ALWAYS buy OEM filters for these trucks. Especially oil and fuel filters.
Kris
2008 Ford F250 6.4L Crew Cab Short Bed King Ranch
3.5" ReadyLift Leveling Kit, 37x13.5x20 Toyo MT's on stock 20's, Dual Steering Stabilizer, Livewire w/ IDP, KEM, Gearhead, S&B, 5" Flo-Pro, Rudy's EGR Delete and Cold Side Pipe, CCV
p8ntballn2 is offline
post #3 of 13 Old 03-31-2013, 01:23 PM
jpfanner's Avatar
Originally Posted by KVB-R View Post
Is this really bad?
Thanks,
Kevin
Listen to what he's saying. DO NOT USE ANYTHING BUT MOTORCRAFT OR RACOR. And make sure your cap is the OE Ford cap. If it's not change it out immediately. Ford filters have special drain back valves and other things that work in conjunction with your cap. If you mix and match you're going to trash your motor. Not to mention FRAM is the worst filter on the planet. A little research will prove that, either on here or just a google search.
Save your 6.4, get Motorcraft gear.
jpfanner is offline
post #4 of 13 Old 03-31-2013, 01:25 PM Thread Starter
KVB-R's Avatar
Yes, the plunger and spring within the big plunger/spring. I'm pretty sure when the little plunger is depressed it just releases the big plunger/spring so you can get the filter cap on....
KVB-R is offline
post #5 of 13 Old 03-31-2013, 01:45 PM
Quoted: 2 Post(s)
not sure what the part number is for that plastic peace.. but in the future, make sure you get OEM filters... or Racor.
Kris
post #6 of 13 Old 03-31-2013, 01:50 PM Thread Starter
KVB-R's Avatar
I definitely will in the future...Anyone have a good online shop to purchase them from? Same with fuel filters?
For right now, I just want be sure that without the little plastic bit there, that I'm still filtering the oil.
KVB-R is offline
post #7 of 13 Old 03-31-2013, 01:53 PM
Mod Newbie
dhanna6powerstroke's Avatar
Quoted: 20 Post(s)
dhanna6powerstroke is offline
post #8 of 13 Old 03-31-2013, 01:54 PM
Quoted: 2 Post(s)
this is where i buy my oil and fuel filters from .... descent prices and fast shipping.
Home - Diesel Filters,Additives,brake rotors, and brake pads for Chevy, Dodge and Ford Diesel Trucks
Kris
post #9 of 13 Old 03-31-2013, 01:54 PM
Quoted: 2 Post(s)
beat me too it!
Kris
post #10 of 13 Old 03-31-2013, 02:38 PM
Quoted: 47 Post(s)
I've used Motorcraft... So the Racors are a good substitute?
2015 F350 DRW Platinum, SCT X4, EDGE CTS2, aFe PDS, AirLift 5000 Ultimate & Wireless Air, Lund LED Bull Bar, RC Grille bar, B&W 5th Wheel, Stark LED Lighting
2010 F250, H&S Mini Maxx, aFe PDS, Diamond Eye 4", Pro Comp Nitro 2.5", Bilstein 5100, SmittyBilt Bull Bar, Bushwacker Pocket Style, B&W Slider, Firestone Ride-Rite, Fuel Hostage 20x10, Pioneer/Kicker/JL Audio
RUFFSTUFF is offline
