Torque converter acting strange? - Ford Powerstroke Diesel Forum
post #1 of 6 Old 03-31-2013, 06:40 AM Thread Starter
2009 cclb 90k miles with tuned hs mini maxx since 35k. been noticing as of late that on the highway when I pass someone and reach about 75-80mph the torque converter unlocks entirely, and remains unlocked even when I let off the pedal for a second or two. Then it locks back up and will unlock again if I try to pick up the speed. This happens with moderate throttle, I rarely ever beat on the truck. I haven't tried recreating the situation under full throttle for fear of causing damage. I get no codes at all. I have wondered if fluid temp makes a difference in this situation but it doesn't seem to matter warm or cold it still happens.
I have read something about the transmission pump losing pressure over time causing this. But I'm not sure. Fluid is clean, but has about 40k miles on the fluid. The transmission feels great in everyday driving and spirited fun. I am positive below 75mph there is no slipping that feels outside of normal operation. I checked fluid level because since the last tranny service it is wet with fluid around the pan. Fluid level looks fine even though the dipsticks are horrific on these new trucks. Does anyone have insight or experience with this? Should I have the tranny flushed and see if that helps?
Have a good one,
Pete
2009 F-350 XLT CC LB 6.4 powerstroke, H&S mini maxx, Flo-pro 5" dp back exhaust, AFE intake...
1977 F-150, built 300 six, M5OD 5 speed
Mercmarquis is offline
post #2 of 6 Old 03-31-2013, 06:42 AM Thread Starter
One quick note, I did update the mini maxx a few weeks prior to this occurrence. Could this be tuning related?
Have a good one,
Pete
post #3 of 6 Old 03-31-2013, 10:49 AM
srjd's Avatar
Quoted: 2 Post(s)
I don't know much about transmissions but if it started after you updated try reloading your tune. It's worth a try
01/07 Job 1 F350 H&S Tuned. ARP Studs, AFE 4'' straight pipe, EGR delete with elbow, AFE stage 2 CAI, 6'' lift on 37s, 20x12 Fuel Nuts two piece, Sinister coolant filter, CCV Mod, Projector headlights HID kit
srjd is offline
post #4 of 6 Old 04-01-2013, 05:40 AM
loganjj27's Avatar
My torque converter was giving me issues while it was changing gears so i changed tune to only lock the torque converter in 5 gear and have had no problems since
Logan Johnston
Sales Associate
Rudy's Diesel Performance
1404 Christian Ave.
Durham, NC, 27705
loganjj27 is offline
post #5 of 6 Old 04-01-2013, 05:24 PM Thread Starter
I used to run the 5th gear lock up only tunes when I first got the mini maxx. Mine would always try to lock it in 4th under hard acceleration right before the 4-5 shift. It was horrible h&s said it should never lock in 4th period running those tunes but mine did. This was two years ago tho. Ill try updating and reloading tonight and see what happens
Have a good one,
Pete
post #6 of 6 Old 04-06-2013, 05:01 PM Thread Starter
I updated the mini maxx and reloaded the tune. I also switched to 5th gear lock up only tunes. Drove it around to relearn and the tranny would still have the same issue over 80mph. From what I can gather here is the order of events. I get on the throttle to around 80-90mph, the rpms begin to rise fast, the mini shows the tc lock icon off, this time i stayed into it, rpms kept climbing fast to 38 - 4k, when I let off and the truck was going maybe 100-105. I let off to coast and around 75-80mph it locks back up and feels good again. Now I'm begining to think this is 5th gear slipping. But I still cant figure why the tq icon comes off. Or why it feels so solid before that speed. Is this the end of the line for my transmission?
Have a good one,
Pete
