Treating a 6.4 like a 6.0 - Ford Powerstroke Diesel Forum
post #1 of 33 Old 03-30-2013, 01:54 AM Thread Starter
BIG Laing's Avatar
Lately I've seen more and more people doing head studs on a 6.4. My question is are you guys so wrapped up in the 6.0 issues that you think you need to do it on your 6.4?
Or are there a lot of people blowing head gaskets on the 6.4's? (I see a 6.4 head gasket blown thread 1% as often as the 6.0 thread...)
2013 Lariat Eco-Boost F150 Super Crew 4x4 20K Miles. Max-Tow 3.73's, luxury package. Amp Steps, Raceline Raptor Wheels, Bak-Flip, and much more.
BIG Laing is offline
post #2 of 33 Old 03-30-2013, 03:13 AM
6.0f250firstcar's Avatar
I don't think it's so much that they're wrapped up in 6.0 issues but more that they want to be safe. They want to know that they can make big power without thinking twice if their HG's will blow. It's not only 6.4 guys that do it too, if you go on the Cummins forums, there are a similar amount of guys with studs as on here. Same with a Duramax forum. The main reason many 6.0 trucks have HG problems even with studs is that there are simply not enough fasteners holding the heads on the motor. Combine the troublesome oil and EGR cooler and 4 Head bolts and its clear why many 6.0's have blown gaskets. However, if you maintain both a 6.0 and 6.4 they should treat you just fine without studs.
Ryan
6.0f250firstcar is offline
post #3 of 33 Old 03-30-2013, 05:56 AM
srjd's Avatar
Quoted: 2 Post(s)
Majority of guys putting studs in a 6.4 is because there gaskets went. Some are spending the money before it happens but most because it all ready happened myself included
01/07 Job 1 F350 H&S Tuned. ARP Studs, AFE 4'' straight pipe, EGR delete with elbow, AFE stage 2 CAI, 6'' lift on 37s, 20x12 Fuel Nuts two piece, Sinister coolant filter, CCV Mod, Projector headlights HID kit
srjd is offline
post #4 of 33 Old 03-30-2013, 06:15 AM
FJuanfiddy mod
Dave's Avatar
Quoted: 10 Post(s)
Tuned 6.4s with intact EGRs pop gaskets nearly as commonly as 6.0s
Email:
2006 F250 ECSB Lariat 4x4
Edge Insight CTS
Coolant filter
Dave is offline
post #5 of 33 Old 03-30-2013, 06:25 AM
srjd's Avatar
Quoted: 2 Post(s)
I thought the egr acted kind of like a waste gate on the 6.4
srjd is offline
post #6 of 33 Old 03-30-2013, 07:33 AM
ramonpowerstroker's Avatar
Aparently not. I don't thing the egrs cause blown head gaskets.... I believe they can bend connecting rods,but not head gaskets... iI it is please explain!
ramonpowerstroker is offline
post #7 of 33 Old 03-30-2013, 07:40 AM
Quoted: 48 Post(s)
not even close!
drunk on diesel is offline
post #8 of 33 Old 03-30-2013, 08:19 AM
I knew it!!! Cylinder pressure kills the head gaskets!!!!!! Exhaust back pressure kills the valve train, and EGR's kill connecting rods, CCV kills piston 2 and 8, and that's it. (Most of these are very rare problems)
post #9 of 33 Old 03-30-2013, 08:37 AM
wilsonw2's Avatar
Quoted: 18 Post(s)
Please explain CCV killing piston 2 and 8 please.
Sent from AutoGuide.com App
*NEW:
2016 F250 CCSB KR FX4
NL Fab:
---Stage 1 Intake
---EGR shmock off plates
---Flo Pro Exhaust (5" to 6" tip)
---SCT with GH tunes
---Waiting for first Fuel Filter change to install:
---------CCV Mod
---------CTS2 monitor with EGT Probe
Just passed 1,111.1 miles and LOVING IT!
**SOLD:
2010 F250 CC FX4
H&S
AFE Intake
and some other goodies...
wilsonw2 is offline
post #10 of 33 Old 03-30-2013, 08:56 AM
Fueling M.A.D. Everywhere
CountryAggie's Avatar
I think he means Regen kills 7 & 8...
I wish ford would just put studs in from factory. Does it really cost that much more if they put them in on the assembly line?
-Tyler
Texas A&M c/o 2010
CountryAggie is offline
