Filter cap says "Carquest DO NOTE RE-USE". WTF??? - Ford Powerstroke Diesel Forum
post #1 of 12 Old 03-29-2013, 04:31 PM Thread Starter
jpfanner's Avatar
OK, so I'm changing the oil in my new-to-me 2008 and once we get the filter housing cap off it says "Carquest DO NOT RE-USE" on the side. OK, so it's an aftermarket filter housing cap, but the filter inside is completely different than the stock 6.4 Motorcraft filter. I mean its longer, skinnier and has different top and bottom fittings where the filter seats on the cap and I guess down inside. Are there different filters/housings on the Job 1's? Do I need to find a FoMoCo filter cap and will the "real" motorcraft filter fit? This is the most puzzling thing I've seen changing the dang oil.
jpfanner is offline
post #2 of 12 Old 03-29-2013, 05:04 PM
srjd's Avatar
Quoted: 2 Post(s)
Very important that you throw that cap in the garbage and get a new oem cap from ford and a oem filter as well
01/07 Job 1 F350 H&S Tuned. ARP Studs, AFE 4'' straight pipe, EGR delete with elbow, AFE stage 2 CAI, 6'' lift on 37s, 20x12 Fuel Nuts two piece, Sinister coolant filter, CCV Mod, Projector headlights HID kit
srjd is offline
post #3 of 12 Old 03-29-2013, 05:21 PM Thread Starter
jpfanner's Avatar
Very much what I assumed. Very saddening. Not to mention I just had brand new 5inch exhaust put on and there is some oil coming out...not sure how much yet but I'm thinking I'm working on borrowed time...
jpfanner is offline
post #4 of 12 Old 03-29-2013, 05:26 PM
srjd's Avatar
Quoted: 2 Post(s)
Oil as in blue smoke or actual oil??
srjd is offline
post #5 of 12 Old 03-29-2013, 05:38 PM
Hunter of Trolls
drewactual's Avatar
Quoted: 65 Post(s)
Ha!! Same thing just happened to me. I paid a joint to change my oil the last time and demanded they use motorcraft, though they didn't..
I picked up a new cap from ford today, along with filter and cetane booster.. just finished changing it out.. i didn't see any leaks or anything, though..
I'm subscribed here though.. would love to know the ramifications of using that filter and cap, if someone would explain it, thanks in advance.
drewactual is offline
post #6 of 12 Old 03-29-2013, 05:47 PM Thread Starter
jpfanner's Avatar
Like sticky, burnt oil...at least I think so...it's all along the bottom of the pipe (on the inside of course) and while I was underneath today I noticed a little pushing out where the muffler connects to the pipe... it doesn't smoke and it doesn't 'run' or 'drip' out...just a filmy sticky residue. Does anyone know if FoMoCo filter caps are expensive? Or should I just get a billet one from RCD? decisions, decisions...
jpfanner is offline
post #7 of 12 Old 03-29-2013, 06:10 PM
muntu's Avatar
so you have just put on a 5" pipe......what was on before.....what tuner you have ?
2008 6.4 job3 F250 3:55 gears 10K gvw silver stretchcab 8ft box.timbrens and goosenek hitch.51 gal aux tank.
muntu is offline
post #8 of 12 Old 03-29-2013, 06:11 PM
Hunter of Trolls
drewactual's Avatar
Quoted: 65 Post(s)
The cetane boost, the filter and the cap cost me $60 today, if that helps you at all..
post #9 of 12 Old 03-29-2013, 06:35 PM Thread Starter
jpfanner's Avatar
I bought it used and it had what appeared to be super clean stock exhaust...the more I look at it the more I'm pretty sure it was either a used system put on after this dealer got it at auction so he could sell it legally or they painted the tail section or something. Anyway. Just a case of people trying to be slick willy's. I drove the truck stock for about 3 days and noticed nothing in the stock pipe.
also I'm running a spartan 210 EL tune right now.
jpfanner is offline
post #10 of 12 Old 03-30-2013, 04:45 AM
05_PSD_Erik's Avatar
Here you go:
Here's one on the fuel filters as well:
2009 Subaru WRX Premium
Type RS BOV
CAI
Muffler Delete
Had to park it with some real diesel muscle....
05_PSD_Erik is offline
