Coolant filter leaking - Ford Powerstroke Diesel Forum
post #1 of 20 Old 03-29-2013, 03:39 PM Thread Starter
srjd's Avatar
Quoted: 2 Post(s)
My sinister coolant filter is leaking from one of the shut off valves. Is there anything I can do to get it to stop. I'm out in the middle of no where and have limited resources
01/07 Job 1 F350 H&S Tuned. ARP Studs, AFE 4'' straight pipe, EGR delete with elbow, AFE stage 2 CAI, 6'' lift on 37s, 20x12 Fuel Nuts two piece, Sinister coolant filter, CCV Mod, Projector headlights HID kit
srjd is offline
post #2 of 20 Old 03-29-2013, 04:09 PM
Feedback Score: 3 reviews
Where is the leak on the valve? Maybe you could just close the valves until you can repair it.
04blackcrewcab is offline
post #3 of 20 Old 03-29-2013, 04:58 PM Thread Starter
srjd's Avatar
Quoted: 2 Post(s)
The valve with the screw in it is what was leaking. I took that whole valve adapter off and just screwed in the bronze fitting that the hose was connected too. The threads matched up but it was hard to screw in hope I didn't strip it. Started it up and so far its holding. I knew those valves would be more of a pita then good. When I get to town I'm just going to buy new fittings and take those valves off.
srjd is offline
post #4 of 20 Old 03-29-2013, 06:48 PM
ramonpowerstroker's Avatar
I had same trouble, I finally got it right after 4 tries
ramonpowerstroker is offline
post #5 of 20 Old 03-29-2013, 06:50 PM
MyTractorsSexy's Avatar
Quoted: 7 Post(s)
mine has slowly leaked too since day one i think it finally got so crusty that it crusted its own self shut lol.
Mild build 07 F250-SOLD
2011 Black CC SB Lariat F250, 2015 Retrofit, MPD IC Piping, H&S Mini Maxx, 5"Flo-pro Exhaust, Sininster Egr Delete, Recon Smoked Lights, No Limit S2 Intake, 20% Tint, BDS 8" 4-Link Lift w/ Fox Shocks & Dual Steering Stabilizer, 4.10 Yukon's with electric lockers, 37/13.50/22 Toyo MT, 2-Piece Fuel Maverick 22x12 Wheels, PTM Grille Surround, T REX X-Metal Grille, LED 6500K heads and fogs, kenwood double din, 4 hertz 210W door speakers 2 JL TW3 10s kenwood amps.
MyTractorsSexy is offline
post #6 of 20 Old 03-29-2013, 06:51 PM Thread Starter
srjd's Avatar
Quoted: 2 Post(s)
Did you take out the valve and just use the bronze fitting or buy new fittings?
srjd is offline
post #7 of 20 Old 03-29-2013, 06:54 PM Thread Starter
srjd's Avatar
Quoted: 2 Post(s)
I noticed my coolant was very slowly disappearing and I thought the worst. Cavitation!! Glad it turned out to be something simple
srjd is offline
post #8 of 20 Old 03-29-2013, 06:57 PM
Yea, I was the same!!! I thought it was a egr failer!!!! I tripped out the first day for 6hours trying to fix it, day 3 I was there for another 6hours.
post #9 of 20 Old 03-30-2013, 07:51 PM
Mine drips too, tightened everything another half turn on the valves and slowed to almost nothing. It has done this from day one.
Tim5113 is offline
post #10 of 20 Old 03-30-2013, 08:24 PM
upd103's Avatar
Send a message via Yahoo to upd103 Send a message via Skype™ to upd103
I was just about to order a kit too. So regardless, DieselSite or Sinister, stay away from the stinking vales?
-David-
upd103 is offline
