Shocked on exit - Ford Powerstroke Diesel Forum
post #1 of 14 Old 03-28-2013, 08:04 PM Thread Starter
sledfreak's Avatar
Shocked on exit
How many of you,get shocked on exit of your trucks? It happens to me more than I can remember any other truck doing to me.Always when I reach to close the door so my feet are on the ground.
08 6.4 250 cc sb lariat loaded white/tan 4x4
H&S Mini HD 300
MCC tunes
7 Kem tunes
Gearhead tunes
AFE S2 SI
Flow-Pro 4"SS
Turbo back
Areo-turbine xl
3"mbrp ci pipe
ccv mod
sledfreak is offline
post #2 of 14 Old 03-28-2013, 08:24 PM
Wannabitawerm's Avatar
Check all your frame to body ground straps. There should be straps from the body to the frame and from the motor to the frame. If they are missing or corroded the body will hold the charge and you are the ground.
Sent from AutoGuide.com App
Wannabitawerm is offline
post #3 of 14 Old 03-28-2013, 08:50 PM
jmhelems's Avatar
Happens to me all the time, I usually shut the door with my elbow because it can be pretty brutal sometimes! I especially notice it in under armour types of clothing, must be something in that material because even around the house its bad. Back on task though, excuse my ignorance on the matter but where are these straps you speak of? How many should there be? I'm sure I speak for Sledfreak when I say I'd love to know more about these because I'd like to fix the problem myself, been getting shocked for too long!
2008 F-250 Badlander...2.5" level, 5" blocks, 35's on 22's, H&S Mini-Maxx, 5" Flo-Pro straight pipe, S&B, KEM
jmhelems is offline
post #4 of 14 Old 03-29-2013, 09:14 AM
tkobes43's Avatar
Quoted: 2 Post(s)
Garage
That happened on my 6.4 for the longest time.. Sold it about a year ago. New owners problem now. lol
Tom
5" MBRP Straight Exhaust w/ 6" tip, SCT Monitored, Limo Tints, 20" LED Lightbar, 8k HIDS, & Some other goodies
Other Rides
1978 Trans Am Y88 403 84k original miles
1996 Ford F350 PSD Mason Dump 134k Original Miles!
Gone But Not Forgotten... (Lilah) 2008 Ford F250 Lariat CrewCab
Proud To Be An American!
tkobes43 is offline
post #5 of 14 Old 03-29-2013, 09:30 AM
pops250's Avatar
Its static electricity. Happens to me no matter what i drive. Seems to be worse this time of year.
pops250 is offline
post #6 of 14 Old 03-29-2013, 09:53 AM
There are woven metal straps that are attached from the body to the frame, engine bloc to the body, trans to the frame, etc. there are usually 2 to 4 on various places. I would pick one up and attach it from the cab to the frame and see if that helps. If not the only other solution is a rubber strap that attaches to the frame and drags the ground. It has metal imbedded to keep the truck grounded.
post #7 of 14 Old 03-29-2013, 10:11 AM
Clayton1985's Avatar
I get shocked by everything all the time, it sucks!! At work Ill go to wash my hands and the water shocks me lol. It gets old!
2008 Job 3, F350, 6.4/drw/lariat/CC/LB, Spartan, Viper 5902, Line-X, Flo-pro egr delete, aFe stage 2 proguard 7, MBRP Cool Duals/downpipe/CAC, CCV mod, coolant filter PMF 7" 4link, Rigid Dually fogs, Royalty Core 3pc, Crown brake lines, Mishimoto Rad
6.4 Rebuild May/2015, BD manifolds+Uppipes, chromoly rods, rockers,lifters, hd springs
Monstir 20", 37x12.50 ATZ P3
1999 Corvette Cpe
Clayton1985 is offline
post #8 of 14 Old 03-29-2013, 12:08 PM
The Maddawg
maddawg89's Avatar
Quoted: 280 Post(s)
Feedback Score: 3 reviews
i am forever getting shocked! Haha my dad is even worse! We get out of the van at church and he'll shut his door and "CRACK!!!!!!" its so funny! BUt sucks too I know. *gets up and goes to truck to check ground straps*
2005 F250 6.0 Powerhouse Lariat
Bully GT Platinum with Quick Tricks
Bully Dog intake
Everything else stock.
Moto Metal 18in rims wrapped in 275/70 Mud Claw Extremes
2003 F250 cclb flat bed.
All stock 7.3 turtle
maddawg89 is offline
post #9 of 14 Old 03-29-2013, 09:59 PM
Yup...been my experience with all my autos. Reason Static is worse in winter is due to lack of humidity...cold air is dry and leads to more static. Few years ago, I had humidifier installed on my home furnace and the HVAC guy told me it would help with static.....he was right!
For your truck or car, try spraying the static cling stuff they make for clothes on the carpet and cloth seats. It will stop the issue.
2010 F350 Lariat, Ready Lift 2.5" level kit, Toyo Open Country AT2-35 x 12.5 R20 on Worx Tyrant rims
sugelle is offline
post #10 of 14 Old 03-30-2013, 05:19 PM
HM-8404's Avatar
As said before it is due to the air being so dry in the winter it causes static electricity to be worse. The best way to solve this, I do it all the time and it works 100% of the time, When exiting your truck make sure you are touching a metal part, either the edge of the door or the side of the truck until you clear the cab.
HM-8404 is offline
