Can I tow a gooseneck with 3" lift kit on a 2008 - Ford Powerstroke Diesel Forum
post #1 of 10 Old 03-26-2013, 09:46 AM Thread Starter
I have a 2008 F250 with 3" lift kit and 37" tires. Before I order the B&W 1108 gooseneck hitch, do you think I would have a problem towing a trailer with that setup?
tictactowing is offline
post #2 of 10 Old 03-26-2013, 01:58 PM
F250Marine's Avatar
You should be ok man, I have seen guys pulling with 6in lifts. I think the longer the trailer the better off you are. With a longer trailer it will ride more level.
F250Marine is offline
post #3 of 10 Old 03-27-2013, 03:54 AM
I haven't had any problems yet towing but I only have 35's. I'm sure you will be fine to tow.
schnet1 is offline
post #4 of 10 Old 03-27-2013, 04:12 AM
I know you shouldn't go over a 4" lift with 35's so you should be ok with 3" and 37's. it also depends on the trailer. A lot of horse trailers have low sides on the neck which are fine hooking up but when you turn they wipe out the side of your bed so be careful about that. However most flatbed goosenecks have a lot of room under there. I would take measurements to be sure cause I know that's a very nice but pricey hitch.
Deezldan is offline
post #5 of 10 Old 03-27-2013, 05:09 AM
NEWT92's Avatar
Boy, not mine. I have a 05 F350 all stock suspension and tire size. I cant adjust my trailer to sit level due to the neck hitting the bed rails on uneven ground.. It sits OK, but not perfect. I cant imagine having a lift.
1968 Chevy Impala Custom Coupe ZZ4 350 700R4 trans 3.55 Posi
2003 F250 XLT 2wd. R/C LWB 7.3 Auto Volant Air Intake 4" Turbo Back Exhaust
2008 F250 King Ranch 2wd Crew Cab Short Bed V10 Auto
NEWT92 is offline
post #6 of 10 Old 03-27-2013, 05:38 AM
Java's Avatar
I have a 3.5 inch Icon lift with 35s and i can pull a trailer just fine (with airbags)
2011 6.7 F350 - Dads
2009 6.4 F350 - Brothers
2007 6.0 F350 - Mine
1997 7.3 F250 - Farm Truck
Java is offline
post #7 of 10 Old 03-27-2013, 07:52 AM
XPLOSIV's Avatar
It all depends on the height of the Gooseneck itself. Like the other guys said... Check the side rails for a good 8 inches or more of clearance. Some guys have lifted their trailers 2-3 inches or done spring over axle conversions on their trailers. Or you can go the other route and have your trailer built for the truck. And having an adjustable goose neck(neck) a stock height truck can still pull the trailer also. 6" with 37's. Truck sits high in the rear without load and level with load.
08 F450 CCLB 4.30's
Spartan, Pure Performance Custom 3", Toyo M608Z, MBRP, FloPro, Banks, Volant, Mishimoto, Dieselsite, LineX, Reese 30k
XPLOSIV is offline
post #8 of 10 Old 03-27-2013, 07:57 AM
XPLOSIV's Avatar
Also, something you could try if you know the trailer you want. Put a piece of 1" plate steel or 3' PT 2x12(to spread the load) in the back of your rig and lower the trailer down on it to see (after sag) what kind of clearance you have or will need. It will atleast get you in the ball park.
08 F450 CCLB 4.30's
XPLOSIV is offline
post #9 of 10 Old 03-27-2013, 07:58 AM
Mod Newbie
dhanna6powerstroke's Avatar
Quoted: 20 Post(s)
B&W also sells a ball that is 3 or 4 inches taller than the stock one which would help too.
dhanna6powerstroke is offline
post #10 of 10 Old 03-27-2013, 08:53 AM Thread Starter
Thanks guys, I went ahead an ordered the hitch. Now I just need to find the trailer Thanks again guys, I feel better now.
Nice rides btw..
