Exhaust back pressure limit before studs - Ford Powerstroke Diesel Forum
post #1 of 8 Old 03-25-2013, 12:23 PM Thread Starter
ramonpowerstroker's Avatar
Hey guys, got a quick question.
I currently run the HD300 tune on my truck. As we all know exhaust back pressure kills head gaskets. Im running my low boost fuel setting at 3. Stock valve train And stock internal parts. What is the most I want to be seeing of exhaust back pressure read off a mini maxx. I know barometric pressure plays along in the equation, but what the programmer reads, what's the safest. I am currently seeing only 65psi of exhaust back pressure that my mini maxx is telling me.
Later on I'm doing studs and valvetrain with the cab on and am going to make a thread of how to do it. I just want to know about the ebp.
ramonpowerstroker is offline
post #2 of 8 Old 03-25-2013, 01:48 PM
WoodBoy's Avatar
The Minimaxx sees gauged pressure. Which means you dont have to subtract any numbers (barometric pressure) from it. It is nice to not go over 70psi on the minimax as it may push the exhaust valves back open at some point after that. Cylinder Pressure has the most effect on headgaskets.
2010 CC/SB FX4 Lariat.. Tuned By Eric@IDP and Matt@Gearhead
Thinking about getting rid of the stock 6.7 turbo?
Check this out... and research before buying
WoodBoy is offline
post #3 of 8 Old 03-25-2013, 07:29 PM Thread Starter
Is there anyway of measuring cylinder pressure? I heard this for this forum, that's why I ask. I know 70 is the top of the top before the valves start floating. When doing studs what can I do to lower back pressure, besides put a wastegate
post #4 of 8 Old 03-26-2013, 06:30 AM
04hdfatboy's Avatar
Quoted: 4 Post(s)
I would say the best way to lower back pressure would be to get rid of the restriction on the exhaust side. I eventually plan to do 6.0 exhaust manifolds (or RCD manifolds, or MPD manifolds) and custom up pipes. This should help the back pressure.
08 F350 cc/sb 4X4
h&s minimaxx, 5" flo pro, 4" down pipe, no limit cold air intake, dirty diesel EGR delete with intake elbow, 6.0 exhaust manifolds, custom up pipes, ported intake manifold, Apex 71mm LP turbo, Rudy's cold side pipe, diesel site coolant and transmission filter, diesel site intercooler boots, ccv mod, bilstein shocks, gogo dd solenoid, HID lights, Airdog II 165, PMF traction bars, PMF drag link, moshimoto aluminum radiator
04hdfatboy is offline
post #5 of 8 Old 12-06-2016, 05:06 PM
Quoted: 4 Post(s)
Just want confirm this is true. 3 weeks ago I did the cat,dpf delete with H&S pro set on the lowest tow setting and using an Edge monitor. I left all the monitor setting the way it came from Edge , everything seemed fine til yesterday the EBP alarm started to go off every time I take off. The Edge alarm was set for 40psi. It idles at 4psi and if you baby it you can keep it bellow 40psi.
Is 40psi to low? all the rest of there pre set parameters seem right.
3skidoos is offline
post #6 of 8 Old 01-22-2017, 11:36 AM
When I first installed the same setup I got the alarm of over pressure. It then went away and has not returned. My pressures normally run 0-2 at idle. I never paid much attention to what they were after the one incident except they were not over 20, even pulling my trailer. Now they are starting to go up and I'm wondering if the muffler is stopping up. One shop said the factory muffler is straight thru and can't stop up. That make me wonder what is causing my pressure to go up.
Does anyone know the "normal" back pressures for highway running, no trailer? I'm running abt 7-8 boost and 16 BP at 65 MPH.
avvidclif is offline
post #7 of 8 Old 01-24-2017, 03:44 PM
Quoted: 4 Post(s)
Mine has also come down so it doesn't alarm now unless I give it lots of throttle. Hwy running is now about the same as yours
3skidoos is offline
post #8 of 8 Old 01-24-2017, 05:57 PM
seanrohatyn's Avatar
Quoted: 9 Post(s)
I would check the sensor and ebp tube. Mine went through the roof one day and fixed itself. I haven't cleaned the sensor or tube yet but I will when the temp warms up for me to work outside. My set up is h&s xrt pro set on hd300 tow. Lbf is set to 2. Using an Edge cts2 monitor.
seanrohatyn is offline
