4WD Malfunction - Ford Powerstroke Diesel Forum
post #1 of 6 Old 03-25-2013, 12:32 PM Thread Starter
4WD Malfunction
When I purchased my 6.4 this last fall, I noticed something was funky regarding the 4WD. When I use the electronic 4WD switch, it doesn't engage. Even when I put it into neutral, switch into 4WD, it still doesn't engage. When Im going down the road and I switch it into 4WD (which I don't usually do. Usually stop completely and switch), it grinds for a second, and not sure if it still kicks in.
I usually just rely on the trusty manual lock-in on the hubs, however, it'd be kind of nice to not have to lock it in. Not sure if this could be an electronic component or something different. Any help would be appreciated. Thanks!
twinturbos is offline
post #2 of 6 Old 03-25-2013, 12:47 PM
WoodBoy's Avatar
Is your 4wd light come on? It sounds like you have a vacuum leak if you are able to manually lock hubs in and use 4x4.
2010 CC/SB FX4 Lariat.. Tuned By Eric@IDP and Matt@Gearhead
Thinking about getting rid of the stock 6.7 turbo?
Check this out... and research before buying
WoodBoy is offline
post #3 of 6 Old 03-25-2013, 12:51 PM Thread Starter
Yes, the light comes on the dash. Are those leaks usually fairly inexpensive to fix? Just weighing my options... If it's too expensive, I'll just leave it as it is and lock in the hubs.
post #4 of 6 Old 03-25-2013, 03:30 PM
Alberta Advantage's Avatar
Quoted: 19 Post(s)
If it's leaking at the hubs, it's pretty pricey to fix. However, vacuum leaks are common and in the system and aren't super expensive to fix. I had a cracked hose and it was a couple hundred to fix. Labor was the costly part of the repair. The parts were cheap. Like said above, a free option to engage 4x4 is to manually lock the hubs. If you have a vacuum leak, you should be able to hear it cycling when you engage 4x4.
09 F350 CCSB SRW Cabela's.
Husky Weather Beaters
Putco Window Visors
Piaa Xtreme White 4k
Dura Flap SS Mud Flaps
Recon Smoked Mirror, Brake, Tails
Line-X
Bak Flip F1
BDS/Fox 2.0 Dual Steering Stabilizer
Fox 2.0 shocks
Good Year Duratracs
Firestone Air Bags
Air Horn
MiniMaxx/5" TBE
No Limit EGR Delete
Vision X Lights
2" Solstice Solo
8" Evo Prime
12" XMitter Low Pro Prime
4" Solstice Prime
20" Evo Prime Double Stack
12" XMitter Prime Ambers
Truck Bed Lights
Alberta Advantage is offline
post #5 of 6 Old 03-25-2013, 05:09 PM
700xxmaniac's Avatar
4WD Malfunction
If its a cracked hose anyone can fix it no need for a shop to do it, just by the hose and 2 new clamps and replace!
Sent from AutoGuide.com App
99 ford f-250 crew cab powerstroke
-skyjacker 6'' lift
- 395-70r-16 mickey tomson baja mtz
-sct tune
-stright pipe (vrrrooom)
-cops are in love with the thing
08 TRX700XX
-uni
-primary drive 13t
-pclll
-cp 11:1
01 recon es 250
-kenda 22'' bear claw
-53mph top speed
700xxmaniac is offline
post #6 of 6 Old 03-25-2013, 05:24 PM
dieselforfun's Avatar
Quoted: 2 Post(s)
Mine seems to engage in 4wh light comes on but not 4wl
dieselforfun is offline
