U0100, u0294 Lost contact with ECM/PCM code, theft light, and limp mode - Ford Powerstroke Diesel Forum
post #1 of 8 Old 03-23-2013, 05:58 AM Thread Starter
jpfanner's Avatar
Just got my truck up here (Ohio) from Louisiana (transported) and it started and came off the truck, then everything went down hill. Drove away and 1/2 mile all the gauges turned off (stopped registering), the dash warning lights were on, go the 'wrench' light the "engine" light, only one gear, etc. Then I hit a bump and everything came back on. I pulled into a dealership and things were fine. I left, pulled out on the interstate, bam limp mode again. Got to a truck stop about 2 miles up the road, filled up with fuel, got back in it. NO START. Theft light flashing. Messed with it for about an hour, locked and unlocked it a few times, then magically it started. Took off towards home, kicked out into limp mode for about a mile, pulled over, stopped went back to normal mode. Got almost home and limp mode again. Got home, shut it down, saw the battery terminals looked like crap so I cleaned them up and checked the batteries. One was weak so I replaced it the other was fine (and newer). It was throwing those two trouble codes that I listed above. Depending on what the dealer says tomorrow this might be a case for "eBay Buyer Protection". We'll see if they'll stand behind the truck or if they make BS up. Also, the lower hose or water pump was pouring coolant out when it warmed up (I know 2010 hoses will fix it IF it's the hoses) If it's the water pump and whatever this is I'm sending it back to the Bayou!!!
That being said has anyone had issues like this? Could it be a broken wire? I know the HPFP was replaced because of a P0880 code very recently. Could they have broke a wire in the wiring harness when they lifted the cab? Maybe a bad ground? God I hope it's simple. Ebay buyer protection after reading the fine print only covers catastrophic engine, transmission, driveline failure. "Electrical" systems are exempt. Well, the way I see it these engines don't run without their electronics so you'd think if it's some crazy $3000 fix that it'd fall under the "buyer protection". Anyone ever dealt with buyer protection?
jpfanner is offline
post #2 of 8 Old 03-23-2013, 06:39 AM Thread Starter
jpfanner's Avatar
I forgot to add that when I get in the truck, NO key in the ignition the CD changer is going nuts like it's searching for a CD for about 2 minutes (even after its started, when it does start) then it reads a CD error. This HAS to be an electrical short right?
jpfanner is offline
post #3 of 8 Old 03-24-2013, 04:12 PM Thread Starter
jpfanner's Avatar
BUMP...HELP...
jpfanner is offline
post #4 of 8 Old 03-24-2013, 04:17 PM
Hunter of Trolls
drewactual's Avatar
Quoted: 57 Post(s)
Maybe obvious, but check the connection at the pcm.. maybe even unclamp them, hit them with some contact cleaner, and reinstall..
drewactual is offline
post #5 of 8 Old 03-25-2013, 05:55 AM Thread Starter
jpfanner's Avatar
It's at Reineke Ford in Findlay. Had to have it towed. As soon it got off the truck it fired right up and drove in the shop. Hopefully he can recreate the issue while it's hooked up to the IDS and get it rolling again. Or, I'm might be flying to Baton Rouge and giving free butt whoopin lessons.
Sent from AutoGuide.com App
2008 CCSB, King Ranch, Spartan Tuned, RCD EGR Delete, RCD Cold Air Intake, AFE CAI, AFE 4in DP, AFE 5in DP back, FASS 95gph, 275/65r20 Nitto Terra Grapplers, PMF Stage 2 trac bars, Elite Up-pipes, 6.0 manifolds, ARP studs, RCD Valve Springs, Chrome-Moly Pushrods, Detroit Locker.
jpfanner is offline
post #6 of 8 Old 03-25-2013, 06:15 AM
Hunter of Trolls
drewactual's Avatar
Quoted: 57 Post(s)
my money is on a bad connection at the PCM, which could have been jostled loose during transport.. or, a short- which could be a dang bear to track down..
best of luck, dude..
word of advise, fwiw: there is no such thing as fighting dirty.. fight to win.. fighting NOT to lose is for little girls..
post #7 of 8 Old 03-25-2013, 06:55 AM Thread Starter
jpfanner's Avatar
Kind of what I'm thinking. Not gonna be fun if it is broke.
jpfanner is offline
post #8 of 8 Old 03-25-2013, 04:33 PM Thread Starter
jpfanner's Avatar
So I talked to a supposed ford Tech online today and he said he's replaced dashboards in a ton of Fords when those codes pop up and he'd bet the farm thats what was wrong with mine. I've searched it a ton and I have found a few instances where this is the case. What do you think?
Another thing I found was a broken chaffed wire in the shift lever. As it goes up and down the wire rubbed and eventually caused a short. The dealer had my truck all day and I never heard from them and so I finally called late in the day, they answer they gave me was, "we got it to duplicate the conditions you described but won't have a diagnoses today, maybe tomorrow..." This will scare me into never buying a truck on ebay again, even though it was from a dealer that had a very good feedback.
jpfanner is offline
