Spare Tire Security Key Help??? - Ford Powerstroke Diesel Forum
post #1 of 9 Old 03-22-2013, 12:08 AM Thread Starter
Mikers's Avatar
Hope someone can help me
On my 350 i need this security Key for the spare tire
But i don't have this card with the 5 Digit numbers for the key
What can i do for find this key ??
I don't would cut the fixening or something else
Is there no possibilty for found out this 5 Digit number with the vin ???
2008 F350 DRW Powerstroke
1993 Ford Bronco 5.8
1990 Ford F150 5.0
1955 Ford Customline
1993 Ford Escort RS Cosworth (Racer)
It exist only Ford and then comes the rest
Mikers is offline
post #2 of 9 Old 03-22-2013, 10:13 AM
69Stang's Avatar
Not much help, but did you try your Stealership?
2010 F250 Cabela's Edition FX4, 6.4L, 3.55LS.
2011 Palomino Throroughbred 828RLS travel trailer.
"Democracy is two wolves and a lamb voting to have lunch. Liberty is a well-armed lamb contesting the vote!" Benjamin Franklin
69Stang is offline
post #3 of 9 Old 03-22-2013, 10:38 AM
Sawed Off's Avatar
Ive never heard of a key to open up your spare tire? new to me. I heard that the number for your door code is sometimes on the top of the computer though
2010 SUPERDUTY
6.4 CREWCAB
Mods so far!!
Smoked Recon lights
Predator8 wheels
Toyo open country tires
Dpf/Doc delete
H&S tuned
S&B cold air intake
Sawed Off is offline
post #4 of 9 Old 03-22-2013, 10:46 AM
floorboy's Avatar
I have a key on both my 7.3 and my 6.4.
Originally Posted by bjs505 View Post
Of course I'm handy under the hood, I currently own a cummins.
2010 F350 CCLB Cabelas Edition
No Limit cai, Mini Maxx, 5" turbo back Flo Pro, Sinister egr delete, Sinister coolant filter, Cat EC-1, PTP shift solenoid. 20x9 +18 XD Monsters
01' 7.3 CCLB, 6637,wicked wheel G2, HPX, PHP Hydra, MBRP 4" Turbo back, Bellowed uppipes, Stancor gpr, 6.0 cooler, Fpr, Glow shift exhaust, pyro, trans, 203*/billet housing/ Cat EC-1, '07headlights/05' grill, Oh8' gate.
78' F350 "dumpy" old school
floorboy is offline
post #5 of 9 Old 03-22-2013, 10:53 AM
44magnum's Avatar
Quoted: 2 Post(s)
When they say you need a "key" for the spare tire they mean a round "key" like they have for lug but locks. Check your glovebox ect. Otherwise google how to remove ford spare tire lock. Edit, found it, use a cheap/old 9/16 socket and pound it on to the "Lock" and drop the tire down with a ratchet and a few extensions. Then get under the truck and pop the "Lock" off with a flat blade screwdriver. Check out this link, he used a nut extractor but I just hammered on a cheap 9/16 socket. He shows it on an 03 f250 but I know from experience it works with ours.
The 5 digit code is only for the door. And if you do a search on here you can find directions for finding the code on some module behind the dash.
[FONT=Verdana][I][B][SIZE=2]2008 (Job 1) F250 King ranch 4x4, snow plow prep package with 2.5 level. Black Maxx, B&W Diehard platinums. Dieselsite coolant and transmission filters, NCU Motorsports/amsoil oil bypass kit. Turbo blankets, 5.5" blocks & PMF "floating" traction bars
44magnum is offline
post #6 of 9 Old 03-23-2013, 12:16 AM Thread Starter
Mikers's Avatar
That my Dealer in the states say to me
(There should be a card in the glove box with a 5 digit Mcgard key code on
it. Mcgard made these for Ford. With that code I can get a replacement
key,
without it you will have to drill it out or cut it off and replace it. See
if the code card is still in the glove box and let me know)
44magnum
Thanks i try that this sunday
That sucks
1990 Ford F150 5.0
Mikers is offline
post #7 of 9 Old 03-23-2013, 05:28 AM
loock1222's Avatar
You can have the dealer remove your key completely.. I lost mine and the dealers have a tool to remove it. Then you just don't have a lock but do you really need it !
2010 F250 Crew Cab Lariat 4x4 / Sun Roof / Nav
1 1/2 leveling blocks upfront
Banks Monster Exhaust w/6" tip
Air Ride bags in the rear with on board air & wireless remote
CCV Mod
loock1222 is offline
post #8 of 9 Old 03-23-2013, 09:58 AM
You don't need an unusual tool to remove the key, you just have to get to it. It's really easy to take it out once you get to it. For me, the easiest way was to unbolt the bed and lift the back of it up 6" or so. It was 8 Towx head bolts on my long box, it's probably 6 on a short box. After lifting the bed up a little I had clear access to the tire mechanism. I took the key thing out, and I just keep an 18" 3/8" socket extension in the truck if I ever need the spare.
The other nice thing about doing this is that now I can take the spare up and down with a drill or impact wrench. Much faster.
You might want to put a chain or cable around your spare to keep it from wandering off though...
B. Adams is offline
post #9 of 9 Old 03-24-2013, 11:53 PM Thread Starter
Mikers's Avatar
So i have do it the same way like the video
And it has works
Now i weld an Socket on the security thing so i can in the future let it down like factory without this **** key
Thanks
1990 Ford F150 5.0
Mikers is offline
