New Shocks, Do I have to get an alignment now? - Ford Powerstroke Diesel Forum
post #1 of 9 Old 03-21-2013, 02:20 AM Thread Starter
Quick question. I have read things both ways and wanted to see what guys here were saying. I just had an alignment done around 15-20k miles ago. Odometer is currently sitting at 86K. Im pretty sure the shocks are shot. They look like they are about to rust off. Any how im replacing them with some Bilstein 24-186018 Fronts and 24-186025 rears. Found them on SDtrucksprings for $80 each. They even had a coupon code for 25 off 250 spent. Sweet deal.
So what I really want to know is replacing shocks cause for an alignment check? Not really wanting to waste the time or the money if its not needed. Currently the tire wear on the fronts are looking good. No issues.
Thanks all,
08 JOB 1 F-250 Lariat Crew Cab, S&B INTAKE, H&S Blk MAXX, 5" Flo PRO, EGR Delete, Air Dog 165, Upgraded Bellows, MBRP Intercooler pipe, 4" Down pipe, Tial Wastegate, OUO T bars, ARP studs, Bestop pwrbrds
***Legal Disclaimer: Anything I say about my vehicle on this website(Powerstroke.org), pertaining to modifications, is only to gain acceptance from my peers, and does not actually represent anything actually existing on my truck, and thus, cannot be held against me in any issues.
08smoker08 is offline
post #2 of 9 Old 03-21-2013, 06:00 AM
04hdfatboy's Avatar
Quoted: 4 Post(s)
No you do not need an alignment after putting new shocks on.
08 F350 cc/sb 4X4
h&s minimaxx, 5" flo pro, 4" down pipe, no limit cold air intake, dirty diesel EGR delete with intake elbow, 6.0 exhaust manifolds, custom up pipes, ported intake manifold, Apex 71mm LP turbo, Rudy's cold side pipe, diesel site coolant and transmission filter, diesel site intercooler boots, ccv mod, bilstein shocks, gogo dd solenoid, HID lights, Airdog II 165, PMF traction bars, PMF drag link, moshimoto aluminum radiator
04hdfatboy is offline
post #3 of 9 Old 03-21-2013, 08:18 AM Thread Starter
Great to know, that saves me some coin and time.
thank you sir,
post #4 of 9 Old 03-21-2013, 08:25 AM
04hdfatboy's Avatar
Quoted: 4 Post(s)
No problem bud
08 F350 cc/sb 4X4
post #5 of 9 Old 03-21-2013, 05:12 PM
HarvestingInternationally's Avatar
how you like the shocks
http://img716.imageshack.us/img716/2580/oppt.jpg
2006
F250 Crew Cab Long Bed 6.0 TurboDiesel FX4
Diesel Site Coolant Filter, Edge Insight CTS, BPD FICM 48v, Metal CAC Tube, Blue Spring,Sinister Diesel EGR Delete w/ Up Pipe, Riff Raff Boots, MBRP 6212-409 Exhaust, BFG AT's,
Bilstein 5100's with Leveling Kit, ISSPRO EV2 Gauges (Pryo
, Fuel Pressure)
Eric
HarvestingInternationally is offline
post #6 of 9 Old 03-22-2013, 07:56 PM
bigal010's Avatar
Man, im having a freaking nightmare trying to get an alignment. I put in 2" daystar level kit in the front and a 1" block in the rear. I aslo put in 4 es9000 procomp shocks and 4 RADD 22" rims and 4 nitto trail grapplers. well before I put the the 22" tires on i took it to ford dealership a couple times to get it aligned. i dont think they did it right even after taking it back twice. so once i put the new tires and rims on, i could really tell it was off. so now im going to have to take it some were else. those tires are high dollar to have a bad alignment. so i think im going to take it to 4wheelparts to have them realign since the only deal with lifted trucks. oh and its gonna cost me another $150 dolloars to do.
BigAl010
bigal010 is offline
post #7 of 9 Old 03-22-2013, 09:48 PM
44magnum's Avatar
Quoted: 2 Post(s)
Originally Posted by bigal010 View Post
Man, I'm having a freaking nightmare trying to get an alignment. I put in 2" Daystar level kit in the front and a 1" block in the rear. I also put in 4 es9000 Procomp shocks and 4 RADD 22" rims and 4 Nitto Trail Grapplers. Well before I put the the 22" tires on i took it to Ford dealership a couple times to get it aligned. I don't think they did it right, even after taking it back twice. So once I put the new tires and rims on, I could really tell it was off. So now I'm going to have to take it some were else. Those tires are high dollar to have a bad alignment. So I think I'm going to take it to 4wheelparts to have them realign since the only deal with lifted trucks. Oh and it's gonna cost me another $150 dollars to do.
4WheelParts is going to charge you $150 for a front end alignment??? That's insane! Didn't the Ford dealer give you a printout of the specs and what they set the truck at?
[FONT=Verdana][I][B][SIZE=2]2008 (Job 1) F250 King ranch 4x4, snow plow prep package with 2.5 level. Black Maxx, B&W Diehard platinums. Dieselsite coolant and transmission filters, NCU Motorsports/amsoil oil bypass kit. Turbo blankets, 5.5" blocks & PMF "floating" traction bars
44magnum is offline
post #8 of 9 Old 03-23-2013, 04:50 AM
That's alot for just a front end alignment
2006
, Fuel Pressure)
Eric
post #9 of 9 Old 03-23-2013, 06:24 AM
bigal010's Avatar
I agree, it is a lot for front end. That's why I took it to the dealership. I had to take it back twice because both times i kept having to hold the wheel more to the left when driving. They did give me a print out that showed all of the alignment specs in the green. However, it seems to be pulling to the left when braking now. And the steering column seems really loose. Maybe i should take to a new dealership? This dealership took all day the first time and half a day the second and still didn't get it right.
BigAl010
bigal010 is offline
