trailer brake module fault ?? - Ford Powerstroke Diesel Forum
post #1 of 5 Old 03-18-2013, 01:03 PM Thread Starter
Quoted: 36 Post(s)
anyone ever get this on the display scrren on the dash? i started getting this alarm and message in the message center. it was dry out and not towing. it goes away but then alarms again off and on. i unplugged the harness in the back and plugged it in but i dont know what or where to look for problem. anyone deal with this before?
gwilkrrs is offline
post #2 of 5 Old 03-18-2013, 01:37 PM
04hdfatboy's Avatar
Quoted: 4 Post(s)
Take off the part where the tailer plugs in to. Sometimes water gets in there and corrodes it. Clean it out and reasemble with dielectric grease. I had the same problem but mine only happened when a trailer was plugged in.
08 F350 cc/sb 4X4
h&s minimaxx, 5" flo pro, 4" down pipe, no limit cold air intake, dirty diesel EGR delete with intake elbow, 6.0 exhaust manifolds, custom up pipes, ported intake manifold, Apex 71mm LP turbo, Rudy's cold side pipe, diesel site coolant and transmission filter, diesel site intercooler boots, ccv mod, bilstein shocks, gogo dd solenoid, HID lights, Airdog II 165, PMF traction bars, PMF drag link, moshimoto aluminum radiator
04hdfatboy is offline
post #3 of 5 Old 03-19-2013, 08:19 AM Thread Starter
Quoted: 36 Post(s)
thanks! what do you use to clean it with?
gwilkrrs is offline
post #4 of 5 Old 03-19-2013, 08:53 AM
04hdfatboy's Avatar
Quoted: 4 Post(s)
i used brake cleaner to clean out the gunk and then i ressambled with dielectric grease. Hope that helps!
08 F350 cc/sb 4X4
post #5 of 5 Old 03-19-2013, 09:21 AM
Quoted: 2 Post(s)
i get this message every time i turn the key on.. very annoying.. but it doesn't cause any issues with the truck or the functionallity of the integrate trailer brake controller or the lights on the trailer or anything. When i comes on.. i just hit the reset button and it goes away until i turn the truck off and back on again. I've checked fuses, wiring, connections, master cylinder connections.. I cant find anything wrong. my tuner doesn't show any codes, but i have a feeling it could be one that it doesn't pick up. and i'm not taking it to the stealership for them to charge me lord knows how much to diagnose something thats not affecting the truck that much. let me know if you figure this out.
Kris
2008 Ford F250 6.4L Crew Cab Short Bed King Ranch
3.5" ReadyLift Leveling Kit, 37x13.5x20 Toyo MT's on stock 20's, Dual Steering Stabilizer, Livewire w/ IDP, KEM, Gearhead, S&B, 5" Flo-Pro, Rudy's EGR Delete and Cold Side Pipe, CCV
p8ntballn2 is offline
