Help figure out what previous owner did with truck - Ford Powerstroke Diesel Forum
post #1 of 5 Old 03-16-2013, 10:43 AM Thread Starter
2010 F350 DRW 4x4 lariat with utility service bed.
There is wiring I believe was for a CB which is a red and black wire from the battery to a connector and I can see where it was mounted under the cup holder. Then there are a couple other wires that run to under the steering colum from the front Drivers side headlight but not hooked up. Then there are some wires that appear to be cut at the drivers side firewall and what appears to me to be some sort of compressor any help is greatly appreciated in figuring this all out. Also does anyone know where the antenna would be run to for the CB its mounted on the rear of the cab but can't find the wire to it.
Narcco is offline
post #2 of 5 Old 03-16-2013, 02:25 PM
travisH3's Avatar
Quoted: 2 Post(s)
Feedback Score: 13 reviews
Those wires in the picture that are capped are wiring from the factory that ford puts in so you don't have to run wires through the firewall your self. You can just use the ones they have there that are capped on the inside too. That other piece next to it with the rubber end should be connected to the vacuum pump at the bottom of the picture.
T-rav
2010 F350 6.4-
s467 MPD single kit, H&S Jesse Byall tuning, No limit IC piping and intake,mishimoto intercooler, MPD billet CCV/oil filler, FASS with sump, SOTA A.W.O.L. polished wheels, toyo rt tires, RED Newton traction bars, oem projector retrofit and a bunch of LED lights LOL
Holderdown Performance #teamHDP
OUR FLEET: 2015 f450, 2014 Platinum F350, 2012 F450 6.7, 2010 F350 6.4, 2005 F350 6.0, 04 F450 6.0
travisH3 is offline
post #3 of 5 Old 03-16-2013, 02:46 PM Thread Starter
What is the vacuumed pump to? There are two parts that look as if its missing a hose on it one pulls the other pushes air.
Narcco is offline
post #4 of 5 Old 03-16-2013, 03:04 PM
travisH3's Avatar
Quoted: 2 Post(s)
That pump runs the blend doors in your truck if it isn't electronic controlled. And also if you have auto 4x4 it locks the hubs for you when left in auto.
T-rav
2010 F350 6.4-
travisH3 is offline
post #5 of 5 Old 03-17-2013, 10:51 AM Thread Starter
Thanks, once I hooked the hose back up it stopped running continuously. Now I just need to find out where the connection to the CB antenna runs into the cab at.
Narcco is offline
