Differential Fluid Change - Ford Powerstroke Diesel Forum
post #1 of 3 Old 03-12-2013, 05:08 PM Thread Starter
I did a search and found some valuable information, however, I would like some additional information.
First, how is the Amsoil diff fluid with these trucks? I always run in everything else, but every vehicle is different. If you like Amsoil, which diff fluid and weight should I use?
Second, I just want to be sure how many quarts I need for the front and rear? Is it 3.5 quarts for the front and 4 quarts for the rear?
Thanks,
Turbo Kidd
2010 Ford F-250 Super Duty, Lariet 4x4, Crew Cab Short Bed, loaded with every option...and more
turbo kidd is offline
post #2 of 3 Old 03-12-2013, 05:57 PM
Quoted: 2 Post(s)
I swapped my rear to amsoil at 50k and it has been great. I just contacted the dealer that I think I met on this site. They know exactly how many quarts you need. Make sure you get the friction modifier.
713Diesel is offline
post #3 of 3 Old 03-13-2013, 04:46 AM
69Stang's Avatar
Will that help with the weak Limited Slip in our trucks?
2010 F250 Cabela's Edition FX4, 6.4L, 3.55LS.
2011 Palomino Throroughbred 828RLS travel trailer.
"Democracy is two wolves and a lamb voting to have lunch. Liberty is a well-armed lamb contesting the vote!" Benjamin Franklin
69Stang is offline
