Oil temp delta, what does Ford actually spec? - Ford Powerstroke Diesel Forum
post #1 of 34 Old 03-12-2013, 08:34 AM Thread Starter
bigt2317's Avatar
I have yet to get a straight answer from searching or even from asking the Ford service manager on what EXACTLY does Ford call out the max difference in temps to be. I read here and there that 10* difference is okay which I understand but what about 15*, 20*, 25*? Where is the cutoff point for a warrantied oil cooler?
Ford just tells me that if it's clogged then it'll will throw a code which is fine and dandy but at what temp difference is the code thrown? I assume my mini maxx turns something off so a code will not be thrown because on a trip I took across Texas a few weeks ago I experienced a max difference of 55* from coolant and oil temp and had an average of 30* difference with no codes. I returned everything back to 100% stock for warranty and while driving with around a 20* difference is threw a code, I cleared it and it didn't "re-throw" that code even when it reached 20* again? Now Ford is saying that my oil cooler is fine because no codes are thrown, I know for a fact my oil cooler is clogged so now I need to find out exactly how to throw that code again.
If Ford will not replace the cooler then I'll go ahead and hook a big *** trailer up and tow it on the highway to get the oil temp up to it's max difference.
Bottom line is, does anyone have a Ford service book or actual knowledge of what they cut off the warranty at temperature wise??
Travis
2008 F350 King Ranch - A few fun things, Newton 2-1/2" leveling kit, HID headlights and fogs, 325/60 Hankook Dynapro ATM2's on stock 20" wheels, Firestone ride rite air bags, Air Lift wireless air controller, B&W gooseneck, Diesel site coolant filter, 30" LED bar
2005 Jeep Unlimited Rubicon - with some stuff
bigt2317 is offline
post #2 of 34 Old 03-12-2013, 08:56 AM
Quoted: 5 Post(s)
I "think" the magic number is 15*, but have heard thru the years they have increased that to 25* before oil cooler replacement.
If they test drive the truck they should be able to verify oil cooler trouble, if they wont warranty it take it to a different dealer.
05 Extended Cab FX4
SCT w/ Gearhead Tunes
Ble-Blah mod...
Edge Insight CTS w/EGT
PHP Tuned FICM-Hercules
a2elvis is offline
post #3 of 34 Old 03-13-2013, 05:36 AM Thread Starter
bigt2317's Avatar
Thanks for the reply a2elvis.
The dealer is replacing the egr valve right now and after that code goes off they will start checking the oil cooler. Maybe today I'll get some sort of answer on that. This dealer is where we buy all our vehicles from and have treated us well in the past so I'm hoping they can figure this out without me going there to throw the code for them.
Travis
bigt2317 is offline
post #4 of 34 Old 03-13-2013, 06:10 AM
floorboy's Avatar
Pardon me, stupid question, new to 6.4's. but why does the oil cooler plug? Lack of oil changes or wrong antifreeze? Thanks.
Originally Posted by bjs505 View Post
Of course I'm handy under the hood, I currently own a cummins.
2010 F350 CCLB Cabelas Edition
No Limit cai, Mini Maxx, 5" turbo back Flo Pro, Sinister egr delete, Sinister coolant filter, Cat EC-1, PTP shift solenoid. 20x9 +18 XD Monsters
01' 7.3 CCLB, 6637,wicked wheel G2, HPX, PHP Hydra, MBRP 4" Turbo back, Bellowed uppipes, Stancor gpr, 6.0 cooler, Fpr, Glow shift exhaust, pyro, trans, 203*/billet housing/ Cat EC-1, '07headlights/05' grill, Oh8' gate.
78' F350 "dumpy" old school
floorboy is offline
post #5 of 34 Old 03-13-2013, 08:15 AM
rt_hawk's Avatar
Junk in cooling system, wrong antifreeze, silicate drop out...scale, lots of stuff...it can also burst from the oil side as well...
I am curious as how a egr delete effects oils temp deltas, seems like after a egr delete people's deltas grow bigger, mine did...while towing it is more noticeable...anyone know the reasons behind this??
Maybe h&s disables that code since they tune for egr delete and deltas would grow larger and set off codes constantly?
2008 F250 XLT CCSB- 90k, 5R110W, b&w hide-a-ball, DIY coolant filter, final charge, dieselsite boots, xrt pro, CAI, SGII, egt gauge, DIY egr cooler blocked/bypassed, viper alarm/ remote start, P/S filter
06 VW Jetta TDI- all options, 100k, stock for now...catching up on maintenance...
04 Triumph Thruxton, cr special carbs, TPUSA cams, MAS side-covers, Lossa stubby exhaust, pingel petc*ck, etc...
rt_hawk is offline
post #6 of 34 Old 03-13-2013, 10:19 AM
04hdfatboy's Avatar
Quoted: 4 Post(s)
My delta did not grow after my egr delete or after my coolant flush. My deltas run 2-4 degrees apart.
08 F350 cc/sb 4X4
h&s minimaxx, 5" flo pro, 4" down pipe, no limit cold air intake, dirty diesel EGR delete with intake elbow, 6.0 exhaust manifolds, custom up pipes, ported intake manifold, Apex 71mm LP turbo, Rudy's cold side pipe, diesel site coolant and transmission filter, diesel site intercooler boots, ccv mod, bilstein shocks, gogo dd solenoid, HID lights, Airdog II 165, PMF traction bars, PMF drag link, moshimoto aluminum radiator
04hdfatboy is offline
post #7 of 34 Old 03-13-2013, 09:36 PM
srjd's Avatar
Quoted: 2 Post(s)
my deltas stayed the same after egr delete as well there usually always 5 when its at operating temp
01/07 Job 1 F350 H&S Tuned. ARP Studs, AFE 4'' straight pipe, EGR delete with elbow, AFE stage 2 CAI, 6'' lift on 37s, 20x12 Fuel Nuts two piece, Sinister coolant filter, CCV Mod, Projector headlights HID kit
srjd is offline
post #8 of 34 Old 03-14-2013, 10:02 AM
rt_hawk's Avatar
Hmm, I reads bunch of posts about trucks running warmer after egr delete, make I am just lucky and get to put in a new oil cooler...oh well...I will do a flush with restore to get all the lime scale out, hopefully that improves things...
rt_hawk is offline
post #9 of 34 Old 03-14-2013, 12:55 PM Thread Starter
bigt2317's Avatar
UPDATE:
Ford called me and told me they fixed the EGR problem but couldn't get the code to come back for the oil cooler warranty. I've asked everyone I can think of as well as Ford service managers and master techs the question of, "At what temp difference does it actually throw a code and to what spec determines that the oil cooler is clogged?", no one can give me a straight answer. I've asked about it in this here also: Oil temp delta, what does Ford actually spec?
I went and picked up my truck this afternoon and told them I'll be right back after it throws the code, well, after about 20 minutes of driving the wrench light popped on. I had my mini maxx plugged in to monitor the temps and I got a max of 61* difference going 75 on the highway, average was about a 50* difference. I was watching for the wrench light but I don't know if it only comes on after a certain delta is hit or if the average is high for a set time or what? I noticed it on when the deltas reached about 40*+.
So I dropped it back off at Ford and hopefully this is the end for the back and forth stuff so it can just get fixed.
You can follow the actual issue in my build thread, link is below in my sig
Travis
bigt2317 is offline
post #10 of 34 Old 03-14-2013, 01:34 PM
rt_hawk's Avatar
I read some where that the light only turns on after so long at certain speeds, I think they give you more leeway at high speed engine operation, etc...look for the tsb that talks about motoring engine temps...it explains it better, good luck! I hope they get it fixed for you!
Edit: I believe the TSB was a recall for a PCM flash, so the truck would throw a light if the oil temp deltas exceeded a certain amount during certain other variables...
rt_hawk is offline
