Scan Gauge 2 Owners - Ford Powerstroke Diesel Forum
post #1 of 15 Old 03-11-2013, 06:52 PM Thread Starter
Scan Gauge 2 Owners
I have a stock 2010 FX4. I was thinking about getting a scangauge 2 to monitor my truck and also have in case I throw a code.
My question is, what do the owners think of them, and can I view my exhaust temp to monitor regens? I am not interested in a programmer.
2010 F-250 CC Lariat FX4 6.4
Fireidiot is offline
post #2 of 15 Old 03-12-2013, 07:49 AM
69Stang's Avatar
I have the Scangauge II and I like it. Of course you know it doesn't have the fancy gauges like some of the others, but the price is right. You can monitor EGT, EGA and DFT. If I remember correctly you have to program those in using the X-Gauge commands, which is a little tedious, but work great.
Scroll down to the 6.4 and it will show you what you can program with the X-Gauge:
Ford Specific XGauges : Linear Logic : Home of the ScanGauge
2010 F250 Cabela's Edition FX4, 6.4L, 3.55LS.
2011 Palomino Throroughbred 828RLS travel trailer.
"Democracy is two wolves and a lamb voting to have lunch. Liberty is a well-armed lamb contesting the vote!" Benjamin Franklin
69Stang is offline
post #3 of 15 Old 03-12-2013, 09:57 AM
rt_hawk's Avatar
Love mine, won't really pick up any codes but my tuner works for that...
2008 F250 XLT CCSB- 90k, 5R110W, b&w hide-a-ball, DIY coolant filter, final charge, dieselsite boots, xrt pro, CAI, SGII, egt gauge, DIY egr cooler blocked/bypassed, viper alarm/ remote start, P/S filter
06 VW Jetta TDI- all options, 100k, stock for now...catching up on maintenance...
04 Triumph Thruxton, cr special carbs, TPUSA cams, MAS side-covers, Lossa stubby exhaust, pingel petc*ck, etc...
rt_hawk is offline
post #4 of 15 Old 03-12-2013, 10:31 AM
69Stang's Avatar
I had a CEL once and was able to retrieve the code using the Scangauge. You have to go into the Scangauge code reader section to read the codes, they won't automatically pop up.
69Stang is offline
post #5 of 15 Old 03-12-2013, 01:44 PM Thread Starter
Out of the X-Gauge codes, which one of the three are the best for monitoring the exhaust for a regeneration? The choices look like: Before Catalyst, After Catalyst, or After DPF.
post #6 of 15 Old 03-13-2013, 04:42 AM
69Stang's Avatar
My understanding is you want to monitor EGT (before catalyst). You can tell when it's in Regen by the EGT temp. I'm sure someone here is more knowledgable then I and can give us a better explanation on which is the best to monitor.
69Stang is offline
post #7 of 15 Old 03-13-2013, 06:15 AM
rt_hawk's Avatar
Most codes that show up on AE or my xrt pro don't show on my SCII, I also went into the scan section to check....pre cat egt is most common to watch, but all will jump up when in regen, you can monitor all of them at the same time to get an idea. The farther down the pipe the cooler they get....
rt_hawk is offline
post #8 of 15 Old 03-13-2013, 07:07 AM Thread Starter
Thanks guys. I appreciate the responses. I will be ordering one soon.
post #9 of 15 Old 03-13-2013, 07:42 PM
I have the SC2 also and I love it. I had the SC1 for years and then upgraded.
Mystic_Cobra is offline
post #10 of 15 Old 07-21-2013, 12:02 PM
glraz's Avatar
I just had my radiator replaced as the dealer said it was leaking. Figured something was wrong couldn't tow the 5er without turning the a/c off and really watching the dash gauge for ect.
I have now installed a ScanGauge II to monitor temps and configured all the xGauges I think I should be watching. DFT, EOT, EGT, EGA TFT are a few. Are there others that would be recommended?
Also trying to find what is normal and acceptable operating ranges for these both under standard driving conditions and towing a 12k 5er.
thanks.
Gary
glraz is offline
