this damn truck... - Ford Powerstroke Diesel Forum
post #1 of 3 Old 03-09-2013, 06:16 AM Thread Starter
Jburcham04's Avatar
this damn truck...
i was driving around town stop and go and shutting truck off and on running in stores. i ran into a store and when i went to leave the truck had no power. wouldnt boost or smoke at full throttle and would only go 10mph. shut the truck off and started back and truck was perfect. i went about my day and everything was fine. the next day my cel came on and truck went into limp mode. codes p0069 and p2262. cleared the codes and truck ran fine for about 50 miles. then the same sequence happened. i did a little research and looked at three sensors 2 at the turbo air intake on the motor and one behind the fuel cooler on driver side valve cover that had a tube running in where the egr bolts up to the exhaust. this motor and these sensors have less than 3k miles. the sensors looked fine. i sprayed some carb cleaner in them and cleaned them. what else should i look for? i have deleted the dpf already so i cant take to dealer for warranty unless i return back to stock. like i said, fresh motor and i know its a sensor somewhere just dont know which one. and i put my gauges to barometer and it red 14, my boost was never negative at idle and it functioned properly even when truck was acting up, fuel pressure was always up and back pressure was usually double the boost when accelerating and would function a little higher than boost when cruise.
ID:	79554   Click image for larger version
ID:	79562   Click image for larger version
08 Job 1 F-350 SRW Lariat 4X4 with Job 3 motor, H&S BM, 5" TB Flo Pro, Hi Flo Air Filter, Traction Bars, Level Kit with 35" Terra Grapplers
Jburcham04 is offline
post #2 of 3 Old 03-09-2013, 07:30 AM
rt_hawk's Avatar
Maybe a stripped wire shorting things out somewhere? Removing and installing a engine seems like a good opportunity to mess up some wires...just an idea...
2008 F250 XLT CCSB- 90k, 5R110W, b&w hide-a-ball, DIY coolant filter, final charge, dieselsite boots, xrt pro, CAI, SGII, egt gauge, DIY egr cooler blocked/bypassed, viper alarm/ remote start, P/S filter
06 VW Jetta TDI- all options, 100k, stock for now...catching up on maintenance...
04 Triumph Thruxton, cr special carbs, TPUSA cams, MAS side-covers, Lossa stubby exhaust, pingel petc*ck, etc...
rt_hawk is offline
post #3 of 3 Old 03-10-2013, 07:47 PM
wilsonw2's Avatar
Quoted: 18 Post(s)
this damn truck...
Update to new tune. Smokes less and less chance of clogging sensors as fast.
Stop speeding through my neighborhood too! My neighbors already hate me enough for the delete and train horns... Haha.
Sent from AutoGuide.com App
*NEW:
2016 F250 CCSB KR FX4
NL Fab:
---Stage 1 Intake
---EGR shmock off plates
---Flo Pro Exhaust (5" to 6" tip)
---SCT with GH tunes
---Waiting for first Fuel Filter change to install:
---------CCV Mod
---------CTS2 monitor with EGT Probe
Just passed 1,111.1 miles and LOVING IT!
**SOLD:
2010 F250 CC FX4
H&S
AFE Intake
and some other goodies...
wilsonw2 is offline
