Going to replace belts tomorrow any tips? - Ford Powerstroke Diesel Forum
Old 03-06-2013, 06:43 PM
Just trying to figure out if any of you guys have done this and if there is any tips y'all could give me?
Old 03-09-2013, 08:06 PM
not bad..about 2-3hr job. Pull the top shroud,careful not to crack it, unplug the fan,removing the plug from the bracket to allow for removal and installation of serpentine belt, I would recommend a tensioner mine went out in the middle of an on ramp with traffic not fun. The latest updated is a 122 tensioner.
Old 03-10-2013, 10:04 AM
At how many miles should you do this or this more of wear and tear visual thing?
Old 03-10-2013, 01:34 PM
For me it's a visual thing. Check the tension to make sure the belt hasn't stretched check for cracks or glazing.
My tip, blare some music so you neighbors can't hear you cussing.
Old 03-10-2013, 04:22 PM
I would replace both belts, both tensioners, and both idlers.
Old 03-10-2013, 04:50 PM
Yeah it's a Turbo Diesel
Feedback Score: 8 reviews
Agreed! I was going to just do my belts, but my diesel mechanic said he did just belts on a customers f250 and a week later his tensioners went out- tow to the shop $300, another $500 for labor and the $390 for tensioners. So I did the tensioners it'll save ya, just do it all while your there, might as well have that front cover checked out too
Sent from AutoGuide.com App
Old 03-10-2013, 05:17 PM
Was not as bad as I thought. Took around 4 hours. Replaced both belts two idler pullys and both tensioners. Scariest part was getting the shroud out without breaking it. Total cost for parts was 340 dollars
Old 03-10-2013, 06:28 PM
MAD - Modification Addict
BEER and LOTS of it.
Old 03-11-2013, 05:42 AM
Are the tensioners and idlers just bolt on/off jobs?
Mine is squeaking so I might as well do it all while i'm at it.
Old 03-12-2013, 08:22 AM
Yes one bolt in each. Very easy. Just takes a little time. I was able to handle them from under the truck the easiest.
