heater problem - Ford Powerstroke Diesel Forum
Old 03-06-2013, 06:29 AM
heater problem
Okay when the truck is at a stop the heater will start to blow cold air once i start moving or get rpm up it will blow hot air again. Anyone know?
Old 03-06-2013, 06:47 AM
Is your coolant low?
Old 03-06-2013, 06:51 AM
^yup... bet you've got a bubble and need a burp, at best, or have a leaking heater core or somewhere else air is being introduced, at worst.
Old 03-06-2013, 07:09 AM
Well f i fill it the coolant comes out of cap. I.did a coolant flush last spring. I didnt have this problem tell a few weeks ago
Old 03-06-2013, 07:10 AM
You have bad head gaskets right? I have seen posts stating that will cause problems with the heater.
Old 03-06-2013, 07:14 AM
I think i goung to replace either way
Old 03-06-2013, 07:15 AM
Well you stated above that coolant comes out of the cap so you probably have bad head gaskets.
Old 03-06-2013, 08:03 AM
Wouldn't temps be weird if it was head gaskets?
