removing speed limiter?
hey guys, this has probably been asked a hundred times but how do you remove the speed limiter with an H&S mini max? just wondering if im missing something here or if its even possible?
It's in the initial install download. There are menus where you can choose the tire size, etc, and the speed limiter is one of the choices. You just need to re-download your tuner to your truck. It's all in the manual if you need a reference while you're doing it. Also, if you haven't updated your Mini Maxx to the new version and firmware, now might be a good time to do it.
And you can't remove the limiter, but you can set it as high as 200MPH, which essentially removes it. I think the limit is initially set at 95 though. Do you often find yourself needing to exceed that? |
