Hissing noise - Ford Powerstroke Diesel Forum
Old 03-05-2013, 06:31 PM
Hissing noise
I have a 08 f250 and was wandering if anyone heard a hissing noise coming from the right side of the truck by the wheel well after turning off the truck? No clue what it is
Old 03-05-2013, 09:31 PM
Send a message via AIM to bmxrules798 Send a message via Skype™ to bmxrules798
I would check to see if you have a boost leak maybe on the hot side intercooler pipe if not that it might be a hole in the intercooler it's self like mine, I have a hole and its a pretty loud hiss.
Old 03-06-2013, 03:21 PM
Ill check it out thanks. And thank you for your service.
Old 03-10-2013, 10:16 AM
Oh boy hissing is usually a boost or exhaust leak. Hopefully it's a boost leak that can be easily fixed. Bad case scenario are the up pipes.
Old 03-10-2013, 10:19 AM
Hopefully. It's a very light hiss that I can hear in my front passenger wheel well
Old 03-10-2013, 05:30 PM
Check for soot. Not a good sign if it's present around your engine.
Old 03-10-2013, 05:41 PM
I revved it and didn't see anything. I recently had the head gaskets replaced. I guess they would have noticed if something was wrong
Old 03-10-2013, 06:47 PM
Re: Hissing noise
Is there ever any squealing while you are accelerating our anything?
Old 03-10-2013, 06:54 PM
Nothing. Runs like a dream.
Old 03-10-2013, 06:57 PM
Re: Hissing noise
Ok. Mine has a broken exhaust manifold bolt and some times it squeals. You may have a look at your manifold bolts just to rule it out.
