A little worried (white smoke content)
Alright, so I am a little worried. I have been reading all the "white smoke threads" after searching the forums here and my problem is still not answered. I am running the H&S mini maxx with a DPF delete and S&B cold air intake. Recently, I started to notice white smoke after I start up the truck and when I rev it while in park. When I rev it up in park, its mixed with black smoke as well. I don't beat on the truck and I have the mild tune set to mild as well and I usually stays there unless I want better mileage on the freeway in which case I turn it up one or two. My coolant is at 186deg, trans temp is 156deg and the oil is 190deg. I had a coolant flush in Nov and drove from Cali here to Missouri in Dec and have been here since. I never checked the coolant really until I saw the white smoke and noticed that it was low by about 2 inches so I filled it to just above the top cold fill line yesterday. Today, while the engine is hot, the coolant is about a millimeter below the bottom cold fill line.
Is this normal for the coolant to fluctuate like that? Since I am puffing white smoke, do you think my EGR has ruptured? I thought the H&S turned the EGR valve off? Could my head be warped or did I blow a head gasket? Have I ruptured a turbo seal? Any help or advice would be much appriciated! Thank you. |
As far as low coolant level i would start by checking for external leaks first. Upper and lower radiator hose, radiator side tanks and hose at rear or horizontal cooler. With dpf delete there will be some smoke. If you are concerned w egr cooler issues just delete them. Tuner will not keep air and coolant flow from going thru coolers if they are still installed. Head gaskets are less likely to be the cause. You can pull the pipe at the back of horizontal cooler loose and check to see if it is wet w coolant.
Sent from AutoGuide.com Free App |
Anybody else have any recommendations? |
Just curious but does it pass w/o the dpf or are you planning on putting it back on for testing?
6.4L Problems - Diesel Power Magazine
scroll down to white smoke/loss of power. Change that boot. personally i changed all 4. 2 hot side from dieselsite.com and other 2 came in my EGR delete kit. |
