hydro boost leaking - Ford Powerstroke Diesel Forum
Old 03-05-2013, 05:09 AM
hydro boost leaking
truck is in the shop for a once over look while they fix the front end issues- he just reported back that the hydro boost is leaking.... how expensive is this to fix?
Old 03-05-2013, 09:02 AM
Feedback Score: 7 reviews
apparently its a common issue. mine was replaced under warranty at 29k miles
Old 03-05-2013, 09:10 AM
there was a TSB for a bushing.. i found out too late after blowing mine and loosing al brakes and steering while turning a corner.. with 38s at the time it made for a fun time
06-22-11***POWER STEERING FLUID LEAK AT JUMPER LINE TO HYDROBOOST CONNECTION - VEHICLES BUILT BEFORE 5/25/2006
its not hard at all to do.. didnt take long at all, just buy the part and do yourself
Old 03-05-2013, 12:09 PM
mine is an 08 with 95k on the clock so i dont think any warrenty still exists.....
Old 03-05-2013, 01:25 PM
hydro boost leaking
Ahh. The TSB I posted wld already be done then as I think 06 or 07 up trucks got the new bushing at the factory so prob not ur issue.
Sent from AutoGuide.com App
Old 03-05-2013, 06:33 PM
Mine is leaking too. Slowly but surely. I just keep the power steering system topped off with Mercon V and deal with the oily spot on my driveway. I'll fix it one of these days, but it's cold out right now. I don't drive my truck everyday, so it doesn't leak very fast. It's definitely worse after pulling a trailer though.
Once it warms up a bit outside I'm planning on pulling mine off to see if it's repairable. I'll fix it if it is and buy a new one if it isn't. I'm expecting it to take a week or two by the time I get all the parts figured out, so I'll have to do it during a period that I won't need my truck. I'm under the impression that the actual swapping out of the booster can be done in under an hour though.
If you buy it new it's roughly a $300-$400 part , depending on where you get it, so it's not a real cheap repair. I'm not sure I'd trust a rebuilt one though.
Old 03-06-2013, 04:42 AM
Ditto, mine is bad on my 2010. I'm going to get mine replaced under warranty....one of these days.
Old 03-06-2013, 04:46 AM
what warrenty covers this? the 3-36?
Old 03-06-2013, 05:38 AM
My Extended Service Plan.
Old 03-07-2013, 02:26 AM
gotcha- i have the extended esp plan but i think thats just motor---- worth a check though!
