Best upgrades for life of the truck
Howdy all,
occasional poster. Questions for the throng if you will indulge me. Have an '08 F-250 crew LB 4x4 w/160kmiles. purchased 14 months ago w/125k. It is a plain jane XL version. It WAS stock. I did a DPF/CAT delete + H&S XRT tuner. I have an Edge CTS for gauges. I run the hot damn tune because I was told on this forum that (+ light foot) would get me the best MPG. I also have EGR delete kit (still have to install) and a coolant filter. The truck has a new radiator as well - stock - to replace leaky old one. I currently get about 16 city and better than 20 on the highway, so I'm pretty happy with the MPG. What I want to know is this... What things should I be putting on my upgrade list to bulletproof this truck so I can get half a million+ miles out of it. I primarily use this truck as a commuter - only because I need a truck around the farm and for the house I am building, and I can't afford a separate commuter car. It also hauls the family on vacation. but time to time, I load it down to full weight on trailers and bed for construction material and rental equipment, backhoes, tractors, plywood, sheetrock etc..... So, where should I start on a list of upgrades I can slowly start adding to extend the life of this truck. I like the better performance from the tuner, and don't mind making it even better, but my primary concern is making the truck as solid and dependable / worry free as I can get it (and yes, i do regular good maintenance). So, what would you put on, and why, and in what order? I can probably afford to drop about 2k per year on upgrades - If I can make the truck last 10 years, that's still cheaper than new trucks, since I only paid 16k for this one, and it's in good shape. Thanks in advance for sharing your wisdom. Oh, and while it is a 250, I wouldn't mind upgrading suspension in mild fashion since I do on rare occasion haul heavy loads - are there any reasonable upgrades to make it more of a 350'ish truck? Not looking for lifts, just heavier loads Ben Last edited by supersecretsquirrel; 03-04-2013 at 12:50 PM. Reason: added thought |
For the towing heavy part, best system would be air bags. You won't sacrifice your current ride and when it's time, press a button or fill manually and it's ready to handle heavier loads.
Thanks for the thoughts Travis.
Any other recommendations out there? I'm kinda stunned by the silence. Am I not cool enough for you guys and your upgrades? |
General 6.4 Modifications |
69stang,
Your right - most were. Thanks for pointing me there. That was a well done thread. |
I'm glad it helped.
Sent from AutoGuide.com App |
