H&s tuned getting 10mpg - Ford Powerstroke Diesel Forum
post #1 of 22 Old 03-03-2013, 09:33 AM Thread Starter
What is going on? Rarely over 20 psi ,stock height, titan 51 gal tank. I've never seen a tuned truck with such low mileage. Any input wanted
Stinkweed14 is offline
post #2 of 22 Old 03-03-2013, 10:00 AM
Fueling M.A.D. Everywhere
CountryAggie's Avatar
Hand calculated? What truck is it (ie year, 250/350/450)? RC/SC/CC and SB/LB? Are you driving a lot of city? A lot of hwy? Traffic? Lots of hills? Loaded? Towing?
Need more info to tell help diagnose.
Sent from AutoGuide.com App
-Tyler
Texas A&M c/o 2010
CountryAggie is offline
post #3 of 22 Old 03-03-2013, 10:08 AM Thread Starter
That's the computer. Sb Cc. City driving mostly unloaded
post #4 of 22 Old 03-03-2013, 10:24 AM
WoodBoy's Avatar
Hand Calculate and report back. What tune are you running? What shift schedule? Low boost fueling setting? Usually the dash reads higher than what you are getting, maybe in your case it is different. You need to check for brakes dragging, 4x4 and stuff.
2010 CC/SB FX4 Lariat.. Tuned By Eric@IDP and Matt@Gearhead
Thinking about getting rid of the stock 6.7 turbo?
Check this out... and research before buying
WoodBoy is offline
post #5 of 22 Old 03-03-2013, 10:25 AM
City driving kills mileage in these trucks (takes a lot to get these things moving... They weigh 8000 lbs minimum). I have noticed that I get better mileage if I get up to speed faster, ie 30-35psi for 30 sec to get to speed rather than 15-20psi for a min and a half to get to speed.
Also what year is it? If its an 08 you probably have 3.73 rear gears. 09-10 has 3.55. Or if you have a 450 or a dually you probably have 4.10 (or taller). Rear end gearing makes a huge difference. The 3.55s will get the best mileage.
To be honest, 10-12 in the city is very normal for these trucks. They weigh a ton.
-Tyler
Texas A&M c/o 2010
post #6 of 22 Old 03-03-2013, 10:35 AM Thread Starter
Mild tune. Lbf 3. Not sure about shift schedule but it goes through the gears pretty quick
post #7 of 22 Old 03-03-2013, 11:31 AM
WoodBoy's Avatar
Turn your LBF down to 0-1 and try S1M or S1L since you are doing a lot of city driving and see if maybe it goes up. Another thing. How much idling do you do?
WoodBoy is offline
post #8 of 22 Old 03-03-2013, 02:55 PM Thread Starter
Not much idling at all
post #9 of 22 Old 03-03-2013, 04:38 PM
What rear end do you have?! That'll help a lot in the suggestions from other org members...
-Tyler
Texas A&M c/o 2010
post #10 of 22 Old 03-03-2013, 05:16 PM
F450Harley's Avatar
What did You expect ?? The MPG can maybe be improved....but by another mile or so. You said city driving (which means not alot of miles per day)....so whats the diff ?
The problem: Its Not a Prius.
The solution: Dont look at the MPG. Keep one eye on the road....and the other on gas stations that sell diesel.When You stop to fill up and go to use the restroom dont expect to smell like Prada in there.
F450Harley is offline
