Sweet Spot
Hey all!! Just got a 250 on Saturday. Been in combustion engine trucks all my life first diesel. Been experimenting with rpms to see where I get the best mileage. Seems to be between 1700 and 1900 rpms. Anyone agree or disagree or have found a better spot. Have to relearn how to drive combustion all about keeping rpms low I understand that diesel is all about compression .
What year???? and Congrats!!!!!!!!
I find if I keep mine under 2k I'm good! |
What you have discovered is the flat nature of a diesel's torque curve. Almost every production 4-stroke diesel produces their most efficient power in the 1600-1900 RPM range. They'll build HP to a certain extent on up to about 3300-3500 RPM, but peak torque doesn't change much.
Hey guys thanks for the quick responses. Its a 2009 and thanks for the congrats. Don't know why I ever drove gas I'll never go back. Had her on interstate with cruise set. In that 1700 to 1900 rpm range I had mpg est in the 20's when I'd decrease speed thus rpms mpg would go down into teens same if I pushed her over 2000 rpms Its pretty cool figuring this stuff out.
Hey do you guys have any recommendations on air intake systems?
I have an S&B CAI (oiled filter) and I like it very much. You will find that most use either the S&B or AFE.
I've found that the 1700-1900 is the sweet spot on my truck also (which for me is probably a little slower speed because I have 3.73 rear end).
As far as tuning, check out the "General 6.4 Modifications" sticky. |
Thats where I will continue to experiment. Some guys have said they really don't even look at speedometer anymore just look at tac. Thank you all for getting back to me
yep 1750rpm's is 65mph for me. 20+or- for winds here in south dakota, next biggest factor here is aerodynamics. i hope im not hijacking too far, but think its on track with the same intentions. Has anyone experimented with engine load % and economy?
*edit to clarify engine load %* I have Spartan tuner that can track engine load. the "early lock" set up for me shift point is 1250rpms and lockup at 45mph. I just switched to the "late lock" same shift points until overdrive which is 55mph. lower load% but higher rpm to get up to speed. Most people floating around forums say early lock is better for mpg. we shall see. Last edited by Joepalmer; 03-19-2013 at 02:19 AM. |
Sweet Spot
I find that 1700 to 1800 with boost below 8 psi tend to provide the best MPG. I yield 19-19.5 HWY with my 3.55s depending on grade changes. Running the CAT DPF delete with a S&B CAI. Next upgrade is replacing the turbo back with a 4" exhaust. I am not expecting much better just cooler EG temps when pulling.
