I am up to the point of getting ready to tap the boost gauge line in. I don't have a T fitting so where do I put this in, Im thinkin drilling into te U tube that connects the turbos and putting it there??
I ran the light power cord to the cluster fuse so when the cluster lights up (head lights on the gauges light up). Im just grounded it to a bolt by the pedals and tightening it down. Im gonna drill a bigger hole in the chassis to fit all the componets through and ill get you all pictures soon.
i drilled the intake elbow on mine, then tapped it. it works great. just make sure you remove it before any drilling or tapping.
Where did you run you gauge light power supply to? We had it installed on the cluster, head lights, and the guages wouldn't power down and I don't want to burn off the battery. Upfitter switches would be awsome but we can't get to the back of those dam things. This is an 08 Lariat edition for more refernce.
Where do you live?
Is this on the 6.4 in your avatar? |
Hampton, VA, yes its the same 6.4
Oh yes the good old Hampton colisum,did plenty of partying there in my day. 25 yrs ago.
