Coolant leaks from cap, normal?
The first time I realized this is last year when I dynoed my truck. I always check my fluid levels and for leaks etc on my truck and it seems that when it got warm and then I really got on it it would leak coolant out of the overflow cap. The fluid would always be in between the fill lines. After I got it dynoed it had a lot of dried coolant on the drivers side of the engine bay and cleaned under the hood. Fast forward to a couple months ago I replaced my cap to a cap that has a larger spring. I didn't have any problems since last summer after the dyno run except right before I replaced the cap, it did it again that's why I changed the cap to see if that was the reason. The fluid when it's cold is right at the bottom of the fill level line. Just the other day I was messing around with some people and when I got home I seen in my drivers side wheelwell some more leaked coolant. Popped the hood and once again you can see where the coolant level rises enough to come out of the cap and can see the dried coolant where it comes around the threads of the cap. Every time I clean the engine bay out so I can see where it comes from if/when it does it again. Is this normal or is there something else to look into?
Might be combustion gasses leaking into your coolant and causing it to puke do to increased pressure. The most common possible causes of 6.4 coolant puking can be:
-bad egr coolers -bad headgaskets -bad cap -coolant level too high Headgaskets may be your issue since your coolant level is good and you removed your egr coolers and have a new cap... |
WHS^^. If your egr coolers are deleted and you replaced the cap its a good chance its your head gaskets.
There could also be fuel in the system, too. That can eat away at the rubber and break down the cap and it can leak that way.
Egr deleted and new cap. Coolant level is good. Guess this only leaves one option. I'll keep a close eye on things. And I've never added coolant, so I guess that's good. Maybe just the first sign of the gaskets
Is there any way you can pressure test the cooling system?
is it bubbling in the degas bottle when you shut the truck off?
No just really full like I over filled it
you've "never added coolant"'? yet, it's burped several times?
when was it last flushed/serviced? was it at operating temperature when it was serviced? what time of season, and how cold does it get there? what was the ratio of coolant to h2o? you may be overfilled, plain and simple.. I think there was a TSB issued at some point that instructed folks to fill just below the bottom line on the old degas bottles.. otherwise, ol' gal would burp.. |
