O-ring leak? - Ford Powerstroke Diesel Forum
Old 02-20-2013, 09:16 AM
O-ring leak?
I discovered a coolant leak this morning, I attached a pic, it looks like there would be an O-ring where the large coolant hose connects to what may be the water pump?, not sure its on the left front, near the lower EGR cooler.. From the parts diagram, it looks like there is 2 different orings for sealing coolant hoses, so I ordered both. I'm deleting the EGR maybe this weekend, so it should be pretty accessible when I get in there. Look familiar to anyone? Am I on the right track?
Old 02-20-2013, 10:33 AM
O-ring leak?
You got it. If that's the one I'm thinking about, there is a tsb on that hose under warranty. They reinstall with a white coolant hose with dual o-rings. The current one You have is single.
I had a leak at the same spot and i had mine replaced after I tuned and deleted her. Hope this helps.
Sent from AutoGuide.com App
