Trans fluid change - Ford Powerstroke Diesel Forum
Old 02-18-2013, 07:29 PM
Trans fluid change
Anyone have any tips on changing the trans fluid on the 6.4? I see there is a drain plug and was unsure if its just that easy or what. Temp is fine (according to mini maxx) and have about 60,000 on the current fluid (was changed when purchased) shifts fine, just want piece of mind.
Old 02-19-2013, 06:24 AM
You can either drop the pan and change the fluid or take it to the dealer for a heated flush. I just drop the pan and change the fluid every year. Its probably overkill but it a nice piece of mind.
Old 02-19-2013, 07:12 AM
Are there any filters to change? Just the pan gasket?
Old 02-19-2013, 07:38 AM
Yes there is a filter to change when you drop the pan. Since you have a job 2 there is no external filter on your truck.
Old 02-19-2013, 09:41 AM
Thanks for the help.
Old 02-19-2013, 09:42 AM
no problem bud. Check out tousley ford or diesel filters online for the filter
Old 02-19-2013, 12:03 PM
How much fluid gets changed with a pan drop? Does the pan have a reusable gasket?
Old 02-19-2013, 12:20 PM
If i remember correctly i used about 8 quarts. Might want to get 9 just to be safe. I cant remember if it has a reusable gasket. Sorry
Old 02-19-2013, 12:24 PM
Re: Trans fluid change
8-9 quarts and I have reused the gasket. I just put a tad bit of gray rtv on it also.
Sent from my SCH-I535 using AutoGuide.Com Free App
