Can i run straight pipe after the dpf? - Ford Powerstroke Diesel Forum
Old 02-18-2013, 07:17 PM
Cool Can i run straight pipe after the dpf?
I was wondering since money is tight and i'd like to hear my truck breath a lil can i run a straight behind the dpf.
Thank you
Ozzy
Old 02-18-2013, 07:31 PM
i am not to familiar with dpf systems but i think it would not do a thing to help it breath better ?
Old 02-18-2013, 07:41 PM
Don't waste your time with it. The dpf is so restrictive that your truck will be just as quiet and choked up.
Sent from AutoGuide.com App
Old 02-18-2013, 07:54 PM
Yes you can, it wont cause any problems, although like Bag711 it wont do much, I have my truck as a full straight pipe from the turbo back and its really not that loud. Also note that when your truck goes into regen your exhaust temps get really hot, and the stock tip helps cool the gasses so you don't light things on fire, so if you remove that as well be careful what you park next to.
Old 02-18-2013, 09:18 PM
with the three guys above me. It does absolutly nothing for sound/performance. It's cosmetic only.
Old 02-19-2013, 01:06 AM
Ok, thanks everyone for all the info.
Old 02-19-2013, 04:02 AM
Think about t like this... You are exhaling thru 2 straws stuck end to end. Now replace the second straw with a funnel. It won't make it any easier to breathe. It's gotta be the whole system to really make a difference.
Old 02-19-2013, 05:15 AM
it's more like you're blowing through three straws and a funnel... and you're talking about replacing that funnel with a bigger funnel
the factory dpf-back is barely more restrictive than a 4" straight dpf-back... it has essentially zero restriction when compared to how restrictive the dpf is
Old 02-19-2013, 03:38 PM
Ok thank you guys for all the help!
Ozzy
