12v power point not working
Hey guys,
I'm hoping you can help me out. I have a 2008 F-250 6.4L. I use the 12v power point on the dash for a monitor and also a cell phone charger. Lately this has been on the fritz, working only intermittently. I changed out the charger for a new one and the problem persists. I checked all the fuses and scraped the connections good....still barely works. (Also the same in the cig lighter) I've never used a multimeter on vehicle power ports, but I have one with dc capabilities. Have any of you had a similar problem? How do I check the power output at the 12v power point? (where to I stick the probes?) How do I test the fuses for continuity or something? Any other advice you can give me? Thanks, MT |
the casing is ground and dead center of the the cig outlet is the power. you may have a loose harness or a bad connector. this sounds like a ground issue more than power.
I bet the two outlets are grounded together then, because both have been sporadic. I suppose I have to tear the dash apart to get to the connections in the back....
I would try swapping the fuse out for those outlets first. Try that sometimes fuses take a partial crap, its a long shot but try. If not I would say its a ground issue. Crown vics used to act up
Ok, fuses checked out fine. But I swapped with new. No luck.
The outlets are getting power, 14.1v or so. The ground continuity reads like 24-31 ohms...should be 0 I think. So, I'm guessing you are correct K1LLs....poor grounding issue. So, now, do I have to remove the dash to check the grounding connections for the outlets? I hope not! Surprisingly, I cannot find anyone with a 6.4L with similar issues or how they solved it. Thanks, |
There are ground studs on the passenger and driver side kick panel. Run a ground from either side to the outlets. Try the new ground wire on the outlets
...back to searching... |
The whole radio bezel will pop out then you will have better access
Thanks, just found this:
Good deal, keep us posted
