Ccv catch can filter question - Ford Powerstroke Diesel Forum
post #1 of 10 Old 02-05-2013, 05:03 PM Thread Starter
Got my moroso catch can today! Quick question about the SOS pad. Right next to the plastic pads at my local grocery store are some copper ones. Does it matter which one I should get as for a filter? Both have the same relative mesh tightness. They both wont rust. Just didn't know if the copper would corrode or not being coated in oil all the time.
08 F350 crew 4x4
H&S mini, Sinister egr delete, cold side pipe, 5" straight pipe, S&B intake, 3.5" level, Newton bars, coolant filter, 325's duratracs, ARP studs, 6.0 manifolds, flow pro DP, Detroit truetrac, triple disk converter, led bed lights
79 F350 4x4 460ci
blk450er is offline
post #2 of 10 Old 02-05-2013, 05:47 PM
Term3's Avatar
Quoted: 2 Post(s)
Get the stainless steel scrubber pads. It's what I used when I made my CCV canister.
SCT, no studs...yet, Dual OEM intake air filter housings, Banks intercooler & intake elbow, Banks exhaust system, Windrunner ported intake manifold, Bullet Proof Diesel remote oil cooler & thermostat, AirDog2 (plus a couple spares), Power steering filter (Amsoil dual-bypass), MagTec deep ATF pan, Electric oil pre-lub pump, Dakota Digital gauges.
Term3 is offline
post #3 of 10 Old 02-05-2013, 05:48 PM
Term3's Avatar
Quoted: 2 Post(s)
Like this..........
Term3 is offline
post #4 of 10 Old 02-05-2013, 05:49 PM Thread Starter
Where did you get those at? I've only seen plastic and copper
08 F350 crew 4x4
79 F350 4x4 460ci
blk450er is offline
post #5 of 10 Old 02-05-2013, 05:50 PM
Term3's Avatar
Quoted: 2 Post(s)
There everywhere up here, grocery stores, Wally World (Walmart)
Term3 is offline
post #6 of 10 Old 02-05-2013, 05:51 PM Thread Starter
Huh, ok thanks
08 F350 crew 4x4
79 F350 4x4 460ci
blk450er is offline
post #7 of 10 Old 02-05-2013, 08:40 PM
h1gg1n5's Avatar
Originally Posted by blk450er View Post
Huh, ok thanks
You can always stop by any machine or fabrication shop and ask them if you can grab a handful of their stainless shavings. They usually have a ton of it around on the floor.
2008 F450 CCLB KING RANCH
H&S Mini Maxx w/ Gearhead Tunes | DPF & EGR Removed | Downpipe | CAC Pipe | CCV Mod | Injen CAI |Dieselsite Coolant Filter & Boots| Mishimoto Rad | BFC Headlights
h1gg1n5 is offline
post #8 of 10 Old 02-06-2013, 04:28 AM Thread Starter
I'll prob use a pot scrubber of some kind. So they stay intact
08 F350 crew 4x4
79 F350 4x4 460ci
blk450er is offline
post #9 of 10 Old 02-08-2013, 04:09 PM
Term3's Avatar
Quoted: 2 Post(s)
Just don't use plastic ones as there is noway to know for sure if they'll stand up to hot hydrocarbon vapors.
Term3 is offline
post #10 of 10 Old 02-09-2013, 05:02 AM Thread Starter
I got stainless scrubbers from menards and a 1" barbed brass fitting with a male threaded end and used a step drill bit to make the hole in the can big enough to thread the fitting in. The fitting fits snugly but I'm epoxying it into the can to be double sure it won't go anywhere.
08 F350 crew 4x4
79 F350 4x4 460ci
blk450er is offline
