Squeaky Pulleys
If any of you are having the same trouble I am with a sqeaking noise when you start up in colder temperatures there is a new TSB out. TSB 07-23-9. They replace the idler pulley and tension pulley. Only thing is I picked the truck up this morning and it still sqeaks. TSB dosen't call for a new belts but the service guy is going to call Ford and see if the belt should be changed.
I'll update when I take it back to the dealer. |
all my trucks have done this in the cold. dont pay much attention to it anymore
Let us know how it turns out, my old 96 has done that this season more than usual, of course it may be something else?
My 08 does the same thing, Sounds like a belt or pulley. I am taking it in this week. Let me know about the belt... thanx
i have a rattle coming from that idler puller when its cold out unless its the alternator
Both my 02 and 96 do it. I put new bearings in all the pullys(the 2 idles and the one tens) and that still didn't fix the problem. Took the pullys off again and took a pick and took the seals off the new bearings and packed them with a good grease. Seems to help a little,but still have a little squeek. Haven't changed the belt yet,but I bet it'll take care of the problem. If it doesn't cure the problem,oh well,I've lived with it for long enough that I hardly even notice it anymore. Let us know how you make out on getting a belt for free.
I wrote this almost two years ago. I had the same symptoms you guys are describing. I hope for your sake it's not the same thing. This was on my 03 6.0.
I think it was a common thing with the 7.3, running so much stuff off of one belt that isn't very wide to begin with. Its got to be about 30 degrees or below before mine even start to do it. Its not a very loud noise either. I think I would of noticed the metal shavings about 100,000 miles ago if that was the problem. But who knows maybe I wouldn't have. I'll pay real close att. next time I change the oil. Thanks for the info.
